My first xr10 http://img.tapatalk.com/6cc8b498-ecf8-e4ee.jpghttp://img.tapatalk.com/6cc8b498-ed06-1b99.jpghttp://img.tapatalk.com/6cc8b498-ed17-dd00.jpghttp://img.tapatalk.com/6cc8b498-ed34-098d.jpg This is my xr10 I just finished. It has a front axle in the rear as well for 4ws and I'm running the shocks in droop and proline interco super swanpers. For electronics I'm gonna run dual tekin fxr and 55t motors, cc bec, hitec 645mg in the rear and a hitec 7950 in the front, and for remote is the traxxas tqi, I know not the best option but is what I have for now. I also replaced the upper links with some bent links from an axial ax10 Sent from my DROIDX using Tapatalk 2 |
http://img.tapatalk.com/6cc8b498-db1d-37da.jpghttp://img.tapatalk.com/6cc8b498-db31-5c3a.jpg This is with my newly painted stock body Sent from my DROIDX using Tapatalk 2 |
Re: My first xr10 Looks good How does the rear steer work? and where do you live in the Bay Area? |
I havent tried it out yet. I'm in san jose. I had a ax10 with rear steer and I loved it so I knew I would want that on this new truck Sent from my DROIDX using Tapatalk 2 |
Re: My first xr10 How hard is it to learn how to use both front and rear steer? |
I have it set up so that they both turn at the same time so it turns sharper all the time. I like it that way Sent from my DROIDX using Tapatalk 2 |
Re: My first xr10 Nice looking rig. I'll assume you don't comp since you can't use 4WS in 2.2.;-) How do those tires hook-up with your normal crawling spot? Side-note: hit "enter" after each picture so they are arranged one above the other. Side to side scrolling can suck.8) |
I don't comp and these tires work very well, I'm pleased with em. I'm using tapatalk so the pics are under each other but I'll do that next time just for you Sent from my DROIDX using Tapatalk 2 |
I took this out for the first time last weekend and it works awesome. The 4ws and the droop suspension is a must to me. Overall I'm very happy with this crawler, my last crawler was an ax10 Sent from my DROIDX using Tapatalk 2 |
http://img.tapatalk.com/aeea02e6-cf1f-3eaa.jpg Heres my new links from blue monkey rc. I also removed the radio box and relocated the reciever and battery Sent from my DROIDX using Tapatalk 2 |
This is my wiring work, I removed the reciever box and relocated the reciever and bent the battery holder to install the battery vertical in the void http://img.tapatalk.com/6cc8b498-7457-521f.jpg This is the rear blue monkey rc links at full flex http://img.tapatalk.com/6cc8b498-7469-8082.jpg This is the front links at full flex http://img.tapatalk.com/6cc8b498-74b7-191f.jpg Sent from my DROIDX using Tapatalk 2 |
