05-07-2012, 04:50 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
| rc4wd gear issue
i know this is just a newbie moa issue but i am putting in my rc4wd gears and the gear under the top link mount is against the plastic and got everything jammed up what have i done wrong?....vp motor plate vp upper link mount and tranny cases.. |
05-07-2012, 04:53 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
| Re: rc4wd gear issue
you need a bearing on the end of the shaft in the 2nd pic...
05-07-2012, 04:56 PM | #3 |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
It looks like you're assembling things in the wrong order. The end of that gear shaft needs a bearing or bushing on it and you won't get the link mount mounted with everything else bolted together. The link mount needs to be screwed to the motor plate before anything else. Do that and things should fall into place nicely.
05-07-2012, 04:56 PM | #4 |
| Re: rc4wd gear issue |
05-07-2012, 05:15 PM | #5 |
You need to either grind done the screw head that attaches the motor plate to the upper link mount or countersink the hole and use a flathead screw. The RC4WD gears are wider than the stock gears and it is binding on the screw. Also ditch the tiny bearing and use a 5x8mm bushing under the upper link mount. Either a Traxxas or Tamiya bushing will do. |
05-07-2012, 05:27 PM | #6 |
Newbie Join Date: Feb 2012 Location: garrison
05-07-2012, 08:41 PM | #7 |
thanks for all the help i got it fixed.. first time ever messing with a moa axle
rc4wd gear issue - Similar Threads | ||||
Spur gear issue??? | jpraccer | Axial Wraith | 2 | 12-26-2011 06:37 PM |
gear issue | Kratos | General Crawlers | 0 | 05-07-2011 08:34 PM |
HELP... Losi MOA gear issue | dirtbuilt | Team Losi Comp Crawler | 20 | 06-13-2010 10:17 PM |
Axial Under drive gear issue. | fusebmx13 | Axial AX-10 Scorpion | 16 | 02-25-2010 07:27 AM |
How to fix the worm gear issue!! | Yawzer | Team Losi Comp Crawler | 44 | 06-02-2009 06:24 PM |
