11-27-2012, 12:34 PM | #41 |
I wanna be Dave Join Date: Oct 2007 Location: 801
| Re: Hittman's SWITCH build
Try raising your front upper links one hole. It should help your tire lift. Edit: I would try standing your front shocks up one hole first. It will allow the spring and oil to work a little more instead of pivoting. (My team drivers don't like the stood up shock, but I love it this way. It seems much more predictable to me.) I would also try raising your rear uppers if you haven't already. Last edited by Chaotic Crawlers; 11-27-2012 at 12:43 PM. |
11-27-2012, 12:47 PM | #42 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
i was woundering aout the oil he was running . to me it looked a little stiff. like my shocks stood p as well a i think he is running his links were i run mine but i no everyone is diff here. al around the rig look like a great starting point |
11-27-2012, 05:14 PM | #43 | ||
| Re: Hittman's SWITCH build Quote:
Thanks man, I really enjoy it, I need to order up the rest of my lw gears, then I should be done buying stuff.. hopefully | ||
11-27-2012, 05:19 PM | #44 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Hittman's SWITCH build |
11-27-2012, 05:21 PM | #45 |
11-27-2012, 05:21 PM | #46 |
11-27-2012, 05:25 PM | #47 |
11-27-2012, 06:19 PM | #48 |
i nhave it now lol
11-27-2012, 06:20 PM | #49 |
i have it now lol
11-27-2012, 06:26 PM | #50 |
11-27-2012, 06:27 PM | #51 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
11-27-2012, 09:34 PM | #52 | |
I found that in really high traction terrain I like my links where you have them, but when I'm at my usual spots(high traction, but not insane traction) I like my rear upper at the highest hole. Your suspension will operate freely still. I run 30 wt oil in all my shocks. I still think standing your shocks up will help with tire lift. If that doesn't fix it, I would raise the fronts up one hole at the chassis. | |
11-27-2012, 09:59 PM | #53 |
is he running the 60 40 or the 50 50
11-27-2012, 10:00 PM | #54 |
Newbie Join Date: Dec 2010 Location: In my tow truck..
Hijack.... When I put my rear uppers in the upper holes, it stopped "pushing" the front end down on steep inclines??? Instead it lifts aND turtle backs.. I am still running the special, but thought id chime in.. Any other suggestions Why have a civilization anymore, if we are no longer interested in being civilized?? |
11-27-2012, 10:06 PM | #55 |
ok i went back an looked he is running 50 50 . ill have to try rasing mine as see what happens . i havent never change mine from where is was when i put it togather . i will say that im running the 60 40 setup on the new truck an it is kinda doing this alil so i will try to move the links around an see what stops it . it is very drivable like it is but hell if it can be better im all for it . this new truck after 4 packs on it is just amazing .
11-27-2012, 10:18 PM | #56 | |
And I'll try the shock placement first.. the front really doesnt lift much and seems very planted.. but maybe I am not seeing something? During my small winter "rebuild" I will change the oil out for 30wt.. 35 is just what I had on hand at the time. Edit: Not trying to be negative on the subject, I really appreciate the help!.. I guess I truly dont know enough about the chassis or rig to know the difference in placement.. Last edited by Hittman; 11-27-2012 at 10:31 PM. | |
11-27-2012, 10:24 PM | #57 | ||
haha jk man, I am happy to hear that the new chassis and links perform even better.. I can only imagine what its like | ||
11-27-2012, 11:38 PM | #58 | |
They all work together. I have tried so many different combos tht I couldn't tell you which ones did what anymore, but I would put my rig up against anybody's on my terrain with the setup I have. Do one thing at a time. Ill be honest... My current shock setup came from a night of drinking and carpet crawling against a wall. I would pull up on a wall enough to get good pressure on the rear tires and then use my hand to see how the suspension would cycle. I found that with my rear uppers all the way up and my front shocks laid down, that my front suspension was locked solid(it didn't cycle.) I started standing up my shocks and tweaking my rear shocks and all of a sudden the suspension would cycle freely and the rig would get completely vertical against a wall unlike my starting setup. | |
11-27-2012, 11:47 PM | #59 | |
11-27-2012, 11:49 PM | #60 |
Good info all around... I get tire lift, but have used it to advantage as well as loss.. I loose front tire pressure/bite when I get too vertical, like standing up, but still get suspension cycle. Now I have to play around too, I guess..
Hittman's SMASH Build - Similar Threads | ||||
Hittman's Featherweight Sporty | Hittman | Axial AX-10 Scorpion | 104 | 05-19-2013 09:08 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
Hittman's mini | Hittman | Losi Mini-Rock Crawler | 17 | 10-01-2012 07:00 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
