11-28-2012, 12:28 AM | #61 | |
I wanna be Dave Join Date: Oct 2007 Location: 801
| Re: Hittman's SWITCH build Quote:
Years ago I used to only focus on link geometry and never even paid attention to shock geometry. Now I play with shock geometry first before I will touch my link geometry. | |
11-28-2012, 12:32 AM | #62 | |
Having your uppers parallel to the ground is a great neutral starting point. I always start there as well, but you can fine tune to your liking from that point. Some may find that parallel to the ground is the best setup for them, but most will find some fine tuning will benefit them even more. | |
11-28-2012, 12:44 AM | #63 | |
12-20-2012, 09:41 PM | #64 |
Well.. this is long overdue.. but here it is.. We had our 3rd comp two Sunday's ago.. Some how I pulled off another 2nd place finish. I drove like $hit! and that is putting it nicely.. But I guess the 30-40mph winds and below freezing temperatures didnt help too much I bought some of the DE racing wheels.. But, I guess you could say my drill press and the wheels didnt get along too well... So, I decided to use my Ytown wheels I had sitting on my shelf. Awsome wheels for sure! And super light with the 4 post design and aluminum screws. I also decided to try the mullet combo again.. From this, I learned that sedona's are some heavy b*tches.. I ran the mullet in the last comp and I wasnt too impressed.. My sporty with all rovers did better.. SOOOoooo I picked up some rovers. These are quite worn, but they are so much better. I siped them, clapped them, and sanded the internal sidewall support.. needless to say, they are light. Sidewall Siping rear wheel/tire weight with 725 vp hub and losi boss claw foam Front wheel/tire weight with 850vp hub + 1/16" dlux spacer and narrowed Pitbull dualstage foam Weight of all the tires and wheels To help save the tire sidewall a little bit, I sanded down my servo arm.. but while it was off.. I figured might as well break out the mother's car polish On the vp steering arm, I moved the hole back and then mounted the drag link behind the servo arm. This really helped! It puts much less stress on the servo, and the servo travel needed for full throw was greatly decreased. Servo travel at full lock Next, I wanted to move the knuckle weights out just a little bit to help with stability.. I found out it couldnt be much, but every little bit helps right? After the last comp.. I switched the cab.. So now it is "backwards" and I seem to like it much better! New clear .020" lexan skins everywhere and it was ready to rock! With the recent changes I have the rtr weight down to: I am hoping the weather cooperates tomorrow so I can get some packs through this thing and some running pics Last edited by Hittman; 12-20-2012 at 09:47 PM. |
12-20-2012, 10:42 PM | #65 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
so what way is backwards
12-20-2012, 10:45 PM | #66 |
| Re: Hittman's SWITCH build I would say this way is "backwards".. I liked it the other way.. but with the clear panels, this way looked much better.. to me atleast |
12-20-2012, 10:47 PM | #67 |
ya now your running it the rite way
12-20-2012, 10:49 PM | #68 |
| Re: Hittman's SWITCH build |
12-20-2012, 11:03 PM | #69 |
Boy, you haven ever seen a warn rover if you call the great looking tire, worn! Broke in, maybe.. no where near warn tho.. great looking job on shaving an siping them.. I also like the "switch" .... Good to hear you.like the cab on in a propper manor! Never mind that.. I thought you ran it the other way an had it on propper now.. Last edited by winnerone23; 12-20-2012 at 11:08 PM. |
12-21-2012, 12:05 AM | #70 | |
You already saw that I changed my cab.. Dont be giving me $hit for a second time Last edited by Hittman; 12-21-2012 at 12:07 AM. | |
12-21-2012, 12:19 AM | #71 |
so your rtr weight is 3 pounds how an the hell u dont this . we have about the same shit an i cant get that low |
12-21-2012, 12:27 AM | #72 |
ok i found it motors lw gears lw hubs an the upper links i guess it all adds up fast im going to be sitting at around 4.5 |
12-21-2012, 12:34 AM | #73 | |
The motors make a difference and the upper links are very nice.. My new panels are also 6grams lighter than the old ones. | |
12-21-2012, 09:38 AM | #74 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
What you are totally running your cab backwards!?!? And you didn't tell me cause you knew I would convince you other wise Oh and you liked my servo arm idea And BTW nice scale perfect for the gram counter like you |
12-21-2012, 02:38 PM | #75 | |
And I know! I didnt really notice how perfect the scale was till last weekend. Pretty bad ass | |
12-21-2012, 10:16 PM | #76 |
I got a few action pics today.. When our club comes back from our "winter break", our first comp is here.. so I figured i might as well get some practice in considering I have never driven this rig there. Goin up! And lastly this one.. I found this rock and I figured it was a good place to practice a jumping gate.. Well, I was definitely was getting some air off of it and figured it would be cool to get a shot of the rig mid air So.. trying to drive one handed and hold a camera with the other had was near impossible to time it right I couldnt get anything to good, so i told "myself "ok, last try, if i dont get anything good i will move on".. well I did get the "best" shot I had, but when I came down there was a loud popping sound I put up the camera, grabbed the rig.. I noticed that the rear motor guard had broke, So i figured that was ok.. then I pushed the throttle.. I am pretty sure the rear motor is not supposed to sound like rocks tumbling in a drum.. I havent taken it apart to see what is wrong, but from the sounds of it, its fawked.. It is very hard to spin the axle too. I will take it apart and see what happened tonight.. Here is the "best" jumping shot I got today.. |
12-21-2012, 10:22 PM | #77 |
RCC Addict Join Date: Jan 2009 Location: O.C
Looks sweet man. Nice job on the build and upgrades!
12-21-2012, 10:33 PM | #78 |
12-21-2012, 10:37 PM | #79 |
It looks great crawling up that first rock! Wicked.... Oh that's right, you Switched ur cab.. haha.. Looks great Christian, I want to come crawl there! Like a grown ups ashtray with rocks... How clocked are ur chubs? One notch past stock mod? Last edited by winnerone23; 12-21-2012 at 10:42 PM. |
12-21-2012, 10:50 PM | #80 | |
Its a nice place.. and yeah, As I was uploading the pics I noticed all the cigarette butts.. Yes, one notch past stock | |
Hittman's SMASH Build - Similar Threads | ||||
Hittman's Featherweight Sporty | Hittman | Axial AX-10 Scorpion | 104 | 05-19-2013 09:08 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
Hittman's mini | Hittman | Losi Mini-Rock Crawler | 17 | 10-01-2012 07:00 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
