12-24-2012, 01:47 AM | #101 |
| Re: Hittman's SWITCH build
Just a small update for tonight... I pulled off the servo plate. I milled and drilled that out a little more.. I am unsure of a un-modified plate but, when i went to weigh this one my scale wouldnt pick it up. And yes, I put something over 3grams on the scale then put the plate on and still nothin.. I am happy with how it turned out.. an it looks pretty cool too. Then I pulled the battery plate off. Drilled out what holes were there and added a few more for good measure this pulled another gram off of the plate.. Nothing much at all, but it is not hurting the overall strength of it, so I do not see a down side to it.. Thats all for tonight.. I just wasnt motivated to work on it anymore.. I am hoping over the next couple days I can get the front gearbox done and a few custom parts put on |
12-24-2012, 10:12 AM | #102 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Did you countersink some of those holes on the battery mount? Looking good What's your RTR weight right now?
12-24-2012, 12:02 PM | #103 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| Re: Hittman's SWITCH build |
12-28-2012, 01:49 AM | #104 | |
| Re: Hittman's SWITCH build Quote:
Not too sure about rtr weight.. the rear motor has been out for a week... I am hoping to get it back together this weekend with some different motors to test | |
01-01-2013, 07:32 PM | #105 |
Ok.. So i finished up the front end over the last couple days.. I got this sweet little servo mount from Calvin at CW.. I had to do a little grinding to get it to fit, but it fits great and looks awesome IMO When I pulled out the gears I had this little suprise waiting for me.. It was still together in the axle but when i pulled it out it seperated.. Soo that got changed out right away. I decided to weigh the gears.. stock vs. axial lw.. I only weighed what gears I replaced and that was the three idler gears and the 1st gear. Not a huge savings but its not bad, and its getting something stronger in there so i cant complain. Sorry for the glare.. Stock: 31grams Axial lw: 26grams Front motor plate got some drilling.. My servo guard I had on wasnt too bad.. but when I saw what my buddy Troy (Winnerone23) was making, I had to have one.. When I first got it, it seemed big and it hung over the sides some.. So after 10-15minutes with the dremel, I had something that fit the size of the servo and I liked much better. A sweet product for sure. Last week I traded some berg axles I had for some team edition Brood vapors.. So far they seem pretty nice. I forgot to weigh the difference between the lw holmes and the vapors, but I dont think there was much difference. They are a 30t, skewed arm, 4 magnet, team brushes and springs.. all i can remember. I also replaced the aluminum timing rings with some lw holmes timing rings.. The brood rings were bent so they had to be replaced anyways... plus the Holmes rings saved 1gram per With all the changes it brought the rtr weight to 3lbs 11.9oz. I am happy with this weight for now.. But a new chassis and motors might be in store for this rig |
01-01-2013, 07:43 PM | #106 |
woah my lil CF mount made your rig loose a ton of weight Looks good on there with the CF guard. I may have to get my self one, it looks nuts |
01-01-2013, 08:00 PM | #107 | |
And you should. The textured cf is really nice and looks good too | |
01-01-2013, 08:04 PM | #108 |
Servo guard looks great! I only run hitec so I guess ill have to get me a futuba to use for moch up, the pic on here is better then the phone, I dint even realize the left side tab was gone.. you must of got that down to 3grams! It will go great with calvins servo mount! Thanks Calvin! |
01-01-2013, 08:14 PM | #109 | |
01-01-2013, 08:19 PM | #110 | |
01-01-2013, 08:26 PM | #111 |
01-01-2013, 08:30 PM | #112 |
Nah..... No futuba for me.. hitec is perfect! That would be like switching from HH motors or chaotic chassis, not gonna happen! heck mise well switch my rovers out for chisels while I'm at it.. hahaha. |
01-01-2013, 08:33 PM | #113 | |
And come on.. live a little.. try new things | |
01-01-2013, 10:22 PM | #114 |
With the vapors I was able to take 3.5mm of the external limiting out of the rear shocks. This gave me 6 1/2" of flex now.. not a ton more but I will have to test it out and see how it handles.
01-01-2013, 11:25 PM | #115 |
01-04-2013, 12:23 AM | #116 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
I love the fact that your rig is on a diet and you are using a weight watchers scale, every pic makes me chuckle a little lol! Im going with the same setup winner is hooking me up with all red and black carbon items, servo mount, guard, all that jazz, going the same direction. I currently have a BWD servo brace, but am also having one made by winner, do you think the weight will be about the same between the CF brace and the aluminum drilled brace you have their?My BWD is already annodized red and is sexy, just wondering if i should switch it! LIK |
01-04-2013, 12:27 AM | #117 |
Be very careful on how you answer the above question Christian! Wahahahahahahahahahaha.....
01-04-2013, 12:40 AM | #118 | |
01-04-2013, 12:43 AM | #119 |
01-04-2013, 08:00 AM | #120 | |
(Very well played, sir). | |
Hittman's SMASH Build - Similar Threads | ||||
Hittman's Featherweight Sporty | Hittman | Axial AX-10 Scorpion | 104 | 05-19-2013 09:08 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
Hittman's mini | Hittman | Losi Mini-Rock Crawler | 17 | 10-01-2012 07:00 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
