05-11-2013, 10:08 PM | #61 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| Re: Frankenwheely's XR10 ReBuild
Right on man.
05-11-2013, 10:19 PM | #62 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Frankenwheely's XR10 ReBuild |
05-11-2013, 10:25 PM | #63 |
05-11-2013, 10:30 PM | #64 |
05-11-2013, 10:37 PM | #65 |
05-11-2013, 10:49 PM | #66 | |
| Re: Frankenwheely's XR10 ReBuild Quote:
To add to this, I'm looking into offering the Voodoo in a "standard" rubber compound (the same compound that other companies use) along side our custom compounds. It will not be a top performer, but it will still perform well. And, at right around $12 per tire, it'll be competitive with other comp tires already on the market. Again, I'm just now looking into this...it may, or may not happen, we'll see. | |
05-11-2013, 11:12 PM | #67 | |
Great News! This news just pimped out my thread. | |
05-12-2013, 12:14 AM | #68 |
Some milling video. Nothing crazy, just a simple video. |
05-13-2013, 08:21 AM | #69 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Good looking Rig Bryce. Not the prettiest knuckle weights for it (love that hole alignment) but the eyeball method has known to be off at times. Luckily gravity is not anal. When time permits some V2's would look much better. Now drive that bad boy! J |
05-14-2013, 01:40 AM | #70 |
Now with the knuckle weight bumped up. I'm happy with the more weight up front. The overall weight isn't much more, which I like as well. Changing the foams, hardware, and cutting the body shed some ounces to help out with the front bias plus keep the overall weight low. Snug fit. No more is going in there. |
05-14-2013, 08:37 AM | #71 |
Yep, all filled up.
05-14-2013, 04:52 PM | #72 |
Looking good! |
05-16-2013, 12:52 AM | #73 |
05-16-2013, 06:49 AM | #74 |
Quarry Creeper Join Date: Oct 2012 Location: Sweden
Frankenwheely: Is that a mill/lathe combo you are using?
05-16-2013, 11:07 AM | #75 |
Yes. But you would have to ask SkaldidDog all the details about it. I just beg and beg until me helps me out. |
05-17-2013, 01:01 PM | #76 |
Rock Crawler Join Date: Jul 2008 Location: San Marcos, CA
Nice looking rig you got there...Were the Voodoo's super grippy at Wohlford? Have you had the chance to run them at any other spots here in SD? My bad, just read your post about sticky icky.... Last edited by RCHuffer; 05-17-2013 at 01:19 PM. |
05-19-2013, 10:21 AM | #77 |
Went foam testing Saturday. Gold with the CI 6 inner med outers need some breaking in. A little bouncy at first, but after a few packs and some time in the sun they were softening up. I'll give it a few more runs to see if this is the set up for me or might switch over to the soft outers to get better results. Like anything you just need the drive time. Moving pictures are coming as well. Last edited by Frankenwheely; 05-19-2013 at 01:21 PM. |
05-19-2013, 06:23 PM | #78 |
05-25-2013, 10:53 AM | #79 |
Booyah Jack! Here you go. |
05-25-2013, 03:50 PM | #80 |
Right on. Looks like ya found a MUCH better setup then the last. You running Golds or Silvers in dat durr flickaroonie? Lisa...awesome job on the cam as usual. REALLY gotta head down this summer for a shoot or 2. JD |
Frankenwheely's XR10 ReBuild - Similar Threads | ||||
Frankenwheely's Wraith Build "Hoofed Hussy" | Frankenwheely | Axial Wraith | 67 | 02-10-2015 12:54 AM |
Jakesy's XR10 video thread ( latest vid-XR10 vs Bully) | jakesy | Videos! | 28 | 05-15-2011 04:49 PM |
