06-18-2013, 02:14 AM | #101 |
| Re: Frankenwheely's XR10 ReBuild
Got some drag tire wrap right there..
06-18-2013, 06:32 AM | #102 |
Get your self some 6" comp cut foams for the front and 6" standards for the rear, it will eliminate that drag slicking.
06-19-2013, 03:00 PM | #103 |
Thanks for the info gents. Went another route. Put my Silvers on with some pin trimming. Used the same foam setup from the golds. I mounted one up with the soft outers. But it felt way too soft. Will be testing these this weekend. Stay tuned. |
06-22-2013, 02:02 AM | #104 |
| Re: Frankenwheely's XR10 ReBuild OUCH! I forgot one of the best pieces of advice of crawling. "Check Yo Rig" after every time you run it. Thought the rig was good. Cut the pins, put more weight in the front. Then took the body off to move the links.... So now I'm on a whole other rebuild. Have a temporary hook up coming, but I'm not sure if its going to be the route I am going to go. If it all works out, I crawling this weekend. |
06-22-2013, 05:52 AM | #105 |
Wow that really stinks. You did a real number to that chassis plate, broken in not one but three places. |
06-26-2013, 10:07 AM | #106 |
Finally have had time to post up. First off I would like to thank Joel (SkaldidDog) and Jake (Del Monte) for helping me get a new rig back together so we could go and crawl. We were like a pit crew, 2 of us working on it at a time. It was crazy. So now this is Rebuild 2.0 I have a 3.5 Secret Agent chassis now with hpi aluminum firestorm shocks. Plus there was a few things I missed that Jake helped out with. The front lower link mounting points on the axle need to be shaved to free them up. And some extra bracing with the chassis and bigger stand offs for the shocks. So after all this we were ready to crawl. Get to the spot and POOF! My battery goes up in smoke. Didn't even get to run it. Took it back to the bench went through all the wiring, looked good. Tried again, same problem. (Sorry Joel about your battery for the second test) Was ready to ditch the fxr combo when we notied that the cap for one of the esc's was crossed over onto itself. Bent it apart and it seems to bee working fine, for now. Can't wait to get this thing out on the rocks. |
06-26-2013, 10:15 AM | #107 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Nice to see your back on the rocks! I was wondering what you had up your sleeve Rob |
06-26-2013, 02:23 PM | #108 |
Looking good Bryce!! Do you run braces between your uppers? I've found that they make the chassis a LOT more rigid. |
06-26-2013, 03:22 PM | #109 |
| Re: Frankenwheely's XR10 ReBuild Don't front. I know all you did was drink beer, take pics and slave drive these two.
06-26-2013, 04:21 PM | #110 |
Yup, Joel and Jake working, Bryce drinking cheap beer and taking pics, sounds about right. |
06-26-2013, 04:42 PM | #111 | ||
| Re: Frankenwheely's XR10 ReBuild Quote:
06-26-2013, 07:10 PM | #112 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Hi Frankenwheely ! The rebuild 2.0 is pretty nice but it couldn't be different with your pit crew !!! I noticed the "hpi aluminum firestorm shocks" and have 2 questions about them : 1 - You have choosen those because you had them ? they were the only thing you had ? 2 - They don't leak ? Why the aluminum version over the plastic one ? Thanks, E. |
06-26-2013, 08:08 PM | #113 |
| Re: Frankenwheely's XR10 ReBuild |
06-26-2013, 09:55 PM | #114 | |
Skaldiddog's "Progress" They haven't leaked on me sitting on the bench yet. I believe he chose the aluminum so he could mill on them and drop some weight. | |
06-26-2013, 09:56 PM | #115 |
06-27-2013, 08:01 AM | #116 | |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Firestorm shocks never leaked on me more than any other shock. I really like them but am a true Traxxas fan and like the grey look over the gold look. With an assortment of springs to test I'm sure they'll work on this rig until he tires of the urban look. | |
06-30-2013, 03:13 PM | #117 |
This thing has been fighting me lately. Took it out today, and noticed that the esc's are running hot. As well as every time I put a new battery, my motors are off. 1st Pack my front is spinning faster, the next pack the rear and vice versa. They are done, Tekin is out on on my rig now. Too many problems. The tires were hooking up when my rig was working. Have a few more mods to make and new parts coming. |
06-30-2013, 05:24 PM | #118 |
What kind/how old are the batteries? Are the motors in need of a rebuild or replacement? |
06-30-2013, 07:22 PM | #119 |
06-30-2013, 07:25 PM | #120 |
Frankenwheely's XR10 ReBuild - Similar Threads | ||||
Frankenwheely's Wraith Build "Hoofed Hussy" | Frankenwheely | Axial Wraith | 67 | 02-10-2015 12:54 AM |
Jakesy's XR10 video thread ( latest vid-XR10 vs Bully) | jakesy | Videos! | 28 | 05-15-2011 04:49 PM |
