Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Clocked C-hubs and tie rod
Old 05-21-2013, 02:10 PM   #1
Default Clocked C-hubs and tie rod
Ok, I've searched about 457,000 different things and can't find the info I'm looking for. I recently upgraded my chubs and knuckles to the axial stage 1 kit. I want to be able to get some more steering out of it too. What is the advantage to clocking the chubs? And is the only option to clock them in the full reverse setting? See pic below. I am planning on going to a tie-rod set up instead of the stock steering and don't want to purchase the wrong tie-rod. And is the high leverage steering arm compatible with the stock xr wheels?
Flame away if need be but I will appreciate any help given.
LooseMoose1978 is offline   Reply With Quote
Old 05-21-2013, 02:16 PM   #2
Copied this from Perkolator
i'm fairly certain that pic is without c-hubs being clocked since the mounting is centered with everything else on the axle - so the caster would be 0* inclination/vertical.
since the 8* steering setup includes king pin inclination, the wheel's camber changes as the wheels turn, thus changing the tire scrub while steering. this has nothing to do with the pinion angle of the axle. IIRC, 8* setup will not clear stock wheels w/stock wheel hex - you'll need either aftermarket wheels with different offset or wider wheel hexes.
if you increase your pinion angle by clocking your axle forward, you've now changed the c-hubs into negative caster angle = wheels steering more into the ground no matter what steering knuckle setup you have. the only way to correct this is to clock the c-hubs in the opposite direction you've just clocked your axle - so the caster is set closer to vertical, like it was originally.
a *similar* setup to the 8* knuckles, would be to have a regular steering setup with the c-hubs clocked back into a positive caster angle - which will also result in camber angle changing as your wheels turn. easiest achieved with either clockable c-hubs or with beef tubes inside axle.
some benefits to having your camber change as your wheels turn: steering tends to want to go back to straight after a turn, less tire scrub, wheels don't fight one another as much, added camber helps steer tire into the object you're trying to climb over = better traction, camber at full steering can help clearance tires from hitting shocks.
this is the best explanation i can personally give since it's a difficult thing to explain without seeing a video or comparison pics of the different setups.
jeepster73 is offline   Reply With Quote
Old 05-21-2013, 03:22 PM   #3
That pic is fully clocked back. The benefit is increased steering. At that position, you want the straight tie rod.
Sent from my SPH-D710BST using Tapatalk 2
Wicked Monkey is offline   Reply With Quote
Old 05-21-2013, 04:54 PM   #4
Default Re: Clocked C-hubs and tie rod
jeepster, thanks for the physics lesson! Do you know if there any diagrams to go along with that?
Wicked Monkey, thanks for the reply. That is what I thought and am going to go with. I wanted to verify before I went ahead and bought the wrong tie-rod.
Old 05-21-2013, 05:01 PM   #5
This might help you out...
http://www.truckaddons.com/Catalog/s...nformation.htm
Old 05-21-2013, 06:51 PM   #6
Thanks jeepster, that was helpful to be able to see some of the concepts I see people on here talking about.
Old 05-21-2013, 06:59 PM   #7
I elongated the screw slots in the C's to clock the C's back more than stock so I could run longer upper links to clock the motor up for more clearance.
And no, the VP knuckles willnot work with stock wheels unless you narrow them.
KBrog is offline   Reply With Quote
Old 05-21-2013, 07:05 PM   #8
I filed the chub to allow me to clock one more slot, and I use Chaotic bent tie rod. Look at their website, and PM him, he will get what you need.
You can also grind down the area at the double shear arm to allow you a bit more steering. With that you will also need to grind down the unit joint to allow smooth operation and move the servo more central so the tire scrub less when you have full left turn.
Colgout is offline   Reply With Quote
Old 05-21-2013, 07:47 PM   #9
Open up the slots so you can run one extra click of caster. Then cut off your lower double shear arm and run the rod ends on top of the upper arm.
Calderwood is offline   Reply With Quote
Old 05-22-2013, 06:32 AM   #10
Thanks for all of the replies, good advice coming in!
Kbrog, I don't have VP knuckles, I got the Axial Stage 1 aluminum kit (chubs, knuckles, lockouts). I installed them last night and they seem to fit with the stock wheels. I haven't had a chance to run it yet but they don't seem to be in the way of anything. But I did try the high leverage steering arm and it seemed to not clear the back edge of the wheel. Do I need to run a narrower wheel with the high leverage arm?
Old 05-22-2013, 06:46 AM   #11
Yes, or one with more offset, wider hub, etc.
Old 05-22-2013, 11:23 AM   #12
Thanks nigel!
Old 08-16-2017, 05:18 PM   #13
I'm looking to improve the steering on my Losi mini crawler rtr version. I have been advised to clock some aluminum c-hubs. What does that mean and how do I do it? Thanks.
sethstiles is offline   Reply With Quote
Old 08-28-2017, 09:48 PM   #14
snapon boy's Avatar
Losi sells 30 degree knuckles
149 r/c worx/scalerfab/team brood.
snapon boy is offline   Reply With Quote
Clocked C-hubs and tie rod - Similar Threads
Tie-rod question tuf-gmh Axial XR10 9 07-14-2012 10:15 AM
toe-in tie rod? klabeaume RC4WD Bully 13 04-09-2010 03:04 PM
KK high clearance tie-rod vs. CKRC OTA tie-rod vs. ?? BigB_117 EnRoute Berg 64 07-06-2009 11:20 PM
