06-05-2014, 06:40 AM | #81 | ||
Quarry Creeper Join Date: Jan 2008 Location: Hellsberry
Sent from a device I've used on the toilet. | ||
06-05-2014, 08:31 AM | #82 | |
Quarry Creeper Join Date: Jul 2009 Location: Woodburn, Oregon
You use a marine grade grease so you don't have to worry about re-greasing your axles. Also use sealed bearings takes care of that problem. After a day of playing submarine WD-40 things down and use a air compressor to blow it off and you're good to go. It's really not that big of a deal. If we were afraid of water we would only crawl three months out of the year. | |
06-05-2014, 08:35 AM | #83 | |
| Re: Sourdough's Rock Spider Re-Build Quote:
I use my phone in the shower too but I has factory conformal coating. | |
01-28-2015, 11:52 PM | #84 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
Overdue for an update on my XR! This poor rig has been down for months. Mainly due to me not taking initiative... But also to my horrible luck with soldering my electronics! I have been working on doing a very compact and water resistant set-up, and I keep letting smoke out of things... I am currently waiting for the Holmes BR mini's to get back in stock. But I did just get a new chassis for this thanks to RcBros!!! Thank you again Will for listening to my suggestions on this beast! |
01-29-2015, 11:28 AM | #85 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
| Re: Sourdough's Rock Spider Re-Build |
01-29-2015, 12:52 PM | #86 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
[QUOTE=sourdojack;5129139]Overdue for an update on my XR! This poor rig has been down for months. Mainly due to me not taking initiative... But also to my horrible luck with soldering my electronics! I have been working on doing a very compact and water resistant set-up, and I keep letting smoke out of things... I am currently waiting for the Holmes BR mini's to get back in stock. But I did just get a new chassis for this thanks to RcBros!!! Thank you again Will for listening to my suggestions on this beast! How to solder correctly (a not so brief lesson) - R/C Tech Forums This will help with keeping the smoke in. |
01-30-2015, 04:31 PM | #87 |
Thanks for the info. I read through that and hopefully next time I will have greater success. Most of my issues are being half drunk and wiring the BEC or ESC backwards lol Call me crazy, but I am going to solder my ESC's, servo, and BEC connections directly onto my Rx. That way it's more compact, and I don't have to worry about poor connections. |
01-31-2015, 10:06 AM | #88 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Your crazy Sent from my iPhone using Tapatalk |
01-31-2015, 12:02 PM | #89 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
The new chassis is looking good too | |
02-02-2015, 05:57 PM | #90 |
02-02-2015, 11:22 PM | #91 |
Man, that sure is some light weight wiring ya got there! |
02-03-2015, 12:18 AM | #92 |
Yeah, it's the new clear electronics. Only required for scalers at this time, but figured I should run em too ;)
02-03-2015, 08:15 PM | #93 |
03-09-2015, 09:40 PM | #94 |
03-14-2015, 08:11 PM | #95 |
Pebble Pounder Join Date: Jan 2005 Location: Toronto, Canada
Beauty!
03-16-2015, 12:42 PM | #96 |
I went over the the RcBros lab on Sunday and got my electronics soldered up. But I forgot to take pictures So when I get back from Birmingham on Thursday I will show you guys/gals how clean they turned out! |
03-16-2015, 01:22 PM | #97 |
03-20-2015, 10:14 AM | #98 |
Great news! Got my truck working finally! No smoke from the ESC's, but my new Brushless Hitec servo isn't working. Had to swap back in my 7950... Here is the RTR weight (Keep in mind, all VP upgrades minus rear axle top) Some pictures of the electronics And some pictures of how tight the tolerances are on the rear suspension Anybody have the top of the chassis get as low as axle center (with straight upper links)? |
03-20-2015, 11:07 AM | #99 |
Whats your upper links made of .....
03-20-2015, 11:30 AM | #100 |
Sourdough's Rock Spider Re-Build - Similar Threads | ||||
Sourdough's SuperSport Truck | sourdojack | Axial AX-10 Scorpion | 145 | 12-10-2015 06:26 PM |
Sourdough's No Name Truck | sourdojack | Axial XR10 | 49 | 11-06-2011 06:30 PM |
The Spider Build | Going Up! | Tamiya TLT Crawlers | 15 | 11-15-2007 05:25 PM |
Spider Monster Rock Crawler????? | shocker | Newbie General | 17 | 01-11-2007 03:28 AM |
