CF Progress Build 1 Attachment(s) Changing everything for Nationals New RCP CF Chassis RCP CF Wheels Shaved Rovers CI DD Foams clocked motors down VP knuckle weights change front links 60/40 set up Deciding on shocks I have run Losi threaded shocks for years, I plan on testing the small Proline shock, SCX10 shock and the Traxxas big bore shock....I'm leaning towards the SCX10 cuz they're so light. The old rig weighted in at exactly 6 lbs The new weight will be under 5 lbs mainly wheels and shocks You can see how far the front axle is clocked back The RR plate is in it's original position. |
Re: CF Progress Build If you put the Big Bores in a lathe and have ti pistonrods you end up at 10g for the big bores. Could be worth 4 grammes total to have a non leaking shock? And i guess you plan on tilting that RR mount up so you get it to the same angle as the links? |
Re: CF Progress Build Quote:
they move they're fine, but I don't like the sticky the RR plate will be moved up ...more pics to follow |
Re: CF Progress Build 2 Attachment(s) got the wheels together ....100 grams less then my lightest wheel and tire I like the link set-up but the proline shocks have to go...putting the SCX10 shocks together now. |
Re: CF Progress Build Very much hoping to win the new progress :) |
Wheels are sick! I think I'm in need of a set of ur 6 spoke wheels! Ready to see this chassis style on the rocks an doin work.. great job |
Re: CF Progress Build New car is looking good Dave! I run the SCX10 shocks on both my shafty, and my MOA cars without leaking. If you eliminate the plastic spacer in the bottom of the shock, and use 3 "O" rings instead, and a 1/16 of an inch "O" ring on the top cap should make those shocks almost leak proof. No issues with mine so far, also the machined piston takes care of the slop on the shock shaft."thumbsup" |
Re: CF Progress Build 3 Attachment(s) she worked very well ...even without knuckle weights but the motors are clocked down too much they got caught up on the rocks a couple times I'll add the RCBROS knuckle weights and clock the motors up a bit |
Re: CF Progress Build Good looking hard line! |
Re: CF Progress Build 1 Attachment(s) Quote:
he won it somewhere ...very nice HARDKNOCKZ is painting another lid for me... to take to Nationals |
Re: CF Progress Build I look forward to seeing it. I will be getting my vendor star in due time and providing painting services. There are a lot of quality painters on here. It will be fun to see how I stack up. Good luck at nats! |
Re: CF Progress Build Builds lookin good Mr. Budd & yes...you DO have a new lid for Nats but the calorie counters wont like it since its LED based ;-) See ya in a few weeks. J.D. |
Re: CF Progress Build 1 Attachment(s) Well the new rig is together... just waiting on the RCBros Wheel Weights I've got a week to tweak before NATS ZoSo Progress CF Chassis Progress 3-hole CF Wheels Dual Sidewinders Tekin 35t Motors Hitec 7950 Servo Rowdy Racing Battery Plate and Motor Plate Chaotic Crawlers Progress TI Links SCX10 Plastic Shocks with Mini Losi Springs Shaved Rovers Crawler Innovations 5.5 Double Deuce Foams Lite/Med Axial XR10 Axles Vanquish Knuckles, "C"s, Cases, Plates, Hex Hubs 850/600 and Upper Link Mounts RC4WD Hardened Gears Traxxas Rod-ends RCBros Wheel Weights Deans Connectors Axial Hardline Body GENS ACE 450mAh Battery Castle Creations 10a BEC Futaba PK4 & R604FS |
Re: CF Progress Build 7 Attachment(s) Had a great time at Nationals...What a great bunch "thumbsup" If you've never gone...you should check it out when Nats comes to your region Here's a few shots of the Rigs |
Re: CF Progress Build Truck looks good! I wish I could have watched it crawl some at Nats...so many thing to do and so little time "thumbsup" Hope to see ya next year at Nats :) |
What did the weight end up at? |
I can still lose a few maybe lighter gauge wire drilled gears |
Re: CF Progress Build 1 Attachment(s) I thought I would try the bodiless one more time it's 3" tall 3" wide 8" long after watching the Fletch U4RC rock racers I went with a Fletch slam concept |
Re: CF Progress Build That roof is 1" above the chassis plates? Btw your roof and hood have to be separate pieces of lexan from my understanding of the rules. |
