08-21-2013, 11:38 AM | #1 |
Rock Stacker Join Date: May 2013 Location: Anchorage
| Robotron's Remedy
Well I started off with a redcat a couple months ago, to see if I like crawlers.. then met up with Alaska RC Crawlers & Offroad through the forum, Now with a little help from my friends Wrenchinrock, KR15 & Whiplashdjs, I'm gathering parts for my new XR10 Remedy, and we're going to put Comp Crawling back on the Map in AK. Any pro tips will be appreciated,..so feel free to chime in about whatever. The Specs will be: BDN Remedy 3.5 Chassis XR10 Axles VP Transmission Case VP Motor Plates RC4wd hardened gears VP Link Mounts VP Lockouts and C-hubs Robinson Racing Pinion gears, CF axle trusses & trans window covers, RC Bros Knuckle Weights 7075 links bent by Wrenchinrock Big Bores, Lathed, cap mod, jeepin doug cups, mini-T springs Rowdy Racing Battery Tray, Turnigy Nano 3s 850mah batteries, Silver DE Racing Wheels -Dyed Dark Green 2x HB Rovers Cut & Shut with HB Block tires, 2x Losi Boss Claws - with shaved sidewalls & trimmed lugs. Holmes Hobbies Torquemaster Motors with CF covers smashed sidewinders, Rowdy Racing Electronics Tray Castle BEC, Hitec HS-7955TG Servo Hacked Flysky FSGT3B remote A couple of pics as it sits, mocking it up and waiting on some parts to arrive. (link material, big bores, knuckle weights, steering parts, servo back from hitec service dept, ect..) |
08-21-2013, 11:42 AM | #2 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: Robotron's Remedy
Wheel color turned out sick.
08-21-2013, 11:47 AM | #3 |
couple questions: When I get my Big bores, should I run them Rightside Up or Upside Down,.. I've seen people set them up both ways.. i'm thinking lower COG with them upside down, but will they clear the tires as well? Also, Should I run the cut & Shut's on the front or rear? & why? |
08-21-2013, 12:34 PM | #4 |
Pebble Pounder Join Date: May 2013 Location: willow
Riteous good to see u representin the 907 man good to see the start of your build thread gonna be a sick @$$ rig altho now i gotta get me another remedy chassis maybe i should see if bdn needs a sales rep ha ha
08-21-2013, 01:58 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Running the hybrids I have found that they seem to perform better with the pins on the outside, so that the larger lugs can grab when reaching ledges. |
08-21-2013, 02:02 PM | #6 | |
| Re: Robotron's Remedy Quote:
08-21-2013, 02:15 PM | #7 |
Agreed. On my dlux chassis, I have no choice but to run them right side up in the rear. If I could, they'd be upside down for sure. Any cog help we can get!
08-21-2013, 04:36 PM | #8 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
I run my big bores right side up. Don't see enough of an advantage to run them upside down. Just my 2 cents and the other thing is I would look into a more powerful servo. The 7955 is barely going to do the job. get a 7950 or 7980.
08-21-2013, 07:51 PM | #9 |
Glad to see another Remedy being built...looking forward to seeing what you think once you get it on the rocks!
08-22-2013, 01:33 AM | #10 |
| im sure he will upgrade as soon as he can i just gave him a warranty repair hitech 7955 so.we could get him on the rocks unfortunately im all outta the 7950s |
08-22-2013, 03:33 AM | #11 |
I was just looking at the specs on Servo Database, & I see what you mean, but it's still 100oz better than the servo on my previous rig, So I'll run it for a bit while I save up for the next round of upgrades. |
08-22-2013, 07:33 AM | #12 |
If you build it as light as you can and run the 7955 on 7v it will work ok. My wraith and my sporty both have 7955s. On 6v they are pretty lame though. My bls157hv in my xr10 is my favorite servo. 514oz-in and .11 sec.
08-25-2013, 10:48 AM | #13 |
Quarry Creeper Join Date: Dec 2011 Location: Us
| Re: Robotron's Remedy SWEEEEET....Keep the pics coming |
08-25-2013, 11:32 AM | #14 |
Thanks for the comments guys, I just got my Holmes Torquemaster Motors and RC Bros Knuckle Weights, So now we're just waiting on USPS with the 7075 rod, smashed sidewinders, and my servo back from Hitec Repair. |
08-25-2013, 11:44 AM | #15 |
| Re: Robotron's Remedy Thanks man, If anyone wants to Dye their wheels like mine, here's the recipe.. 1.5 quarts of water, heated to just under boiling 1/2 bottle of Dark Green Rit Fabric Dye Stir in one package of washed & rinsed Silver DE Racing Wheels, and let them stew for 4 minutes, checking color frequently. Keep the wheels in for the same amount of time to keep the color even, and have some metal tongs ready to remove the wheels from the dye. -Rinse with Cold Water |
08-25-2013, 06:48 PM | #16 | |
08-25-2013, 07:24 PM | #17 |
Newbie Join Date: Sep 2011 Location: Southeast asia crawling fields
Nice wheel combo!
08-26-2013, 07:05 PM | #18 |
The Big Bores arrived today, `Thanks again Hoppa! Chassis weight under 60g ! Wheels under 50g for the set |
08-26-2013, 09:46 PM | #19 |
Just ordered: RPM 80511 Long Rod Ends (12), Dyeable White RPM 80471 Short Rod Ends (12), Dyeable White Traxxas 5355X Aluminium Hollow Balls Set (32) |
08-26-2013, 10:32 PM | #20 |
dyeable im sure your thinkin more green |
Robotron's Remedy - Similar Threads | ||||
*** your remedy 3.5 *** | BDN | Chassis and Suspension | 123 | 08-14-2016 04:46 PM |
M_ENERGY's -- Remedy 3.5 | M_ENERGY | Axial XR10 | 255 | 07-14-2015 01:02 PM |
Could This Be The Real Clod Stall Remedy? | jeepfreek | Tamiya Clod Buster | 13 | 02-27-2008 11:59 AM |
Found a spring remedy.... | wanabgts | General Crawlers | 1 | 08-22-2005 05:42 PM |
