Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: wheel / tire advice
Old 08-25-2013, 07:38 AM   #1
Default wheel / tire advice
I am looking for some help / recommendations on wheels and tires for a Chaotic XR 10. Right now I have an older set of VP DH Comps on it. I have always ran aluminum beadlocks but want to make the move to carbon or G10. All the option with the different styles are a little overwhelming.
Also looking for advice on foams. I have read a lot about open and closed cell. I have mostly used Sedona's with the "stock" foam.
I live in NY outside of NYC and looking to run a few comps this fall. Terrain here is granite and bluestone rock that is more smooth then rough.
Thanks in advance.
cmlooner33 is offline   Reply With Quote
Old 08-25-2013, 07:43 AM   #2
Default Re: wheel / tire advice
What is the weight of your rig? That has a bit to do with tire & foam choice.
Charlie-III is offline   Reply With Quote
Old 08-25-2013, 07:58 AM   #3
heavy with the DH COMPS. It is a Chaotic Switch with smashed electronics and the usual VP bits for the axels. Ideally with the right wheels I would like to see it mid 4 pound range.
hope this helps.
Chris
Old 08-25-2013, 08:29 AM   #4
Fifth dimension
Crawllife's Avatar
My go to response to this question is dlux fab. I've never had one issue with his wheels. Tough as hell and he has a weight system for them.
Crawllife is offline   Reply With Quote
Old 08-25-2013, 12:10 PM   #5
For max weight drop, their are lots of glue on options, from 8g to 24g..
For weight drop an beadlocks, a couple options.. as David said, Dlux CF beadlocks are tough as hell an look great doin it!
As the DH wheels are Heavy.. even VP slws would be a good weight loss..
For a mid 4lb rig, I ran CI 5.25" foams in my rovers and boss claws. Not sure if its the same with the dona's.. maybe a 5.5" CI setup. Soft front, med rear..
winnerone23 is offline   Reply With Quote
Old 08-25-2013, 12:15 PM   #6
I have some SLW V1 on my shafty. Like them a lot. Going to look at D LUX and some knuckle weights.
Old 08-26-2013, 11:21 AM   #7
My vote is the DLUX cf beadlocks. Yes i know the trend is glue these days but I like the no hassle of changing things up with the beadlocks. I have had my set of DLUX cf's for over a year now and they have never lost a bead and I only run 3 screws per face and 3 per hub. Also note they have taken some big falls with no issue!!! Tough as nails and if by some chance you break or need a different look peices are available separately!!!
mammoth is offline   Reply With Quote
wheel / tire advice - Similar Threads
Tire/wheel advice for basher optikalillushun Tires and Wheels 3 12-01-2012 08:36 AM
Tire Advice Sh0rtBus Losi Mini-Rock Crawler 17 08-17-2012 01:44 AM
Need advice on wheel and tire choice!!! Chaotic Crawlers Superclass Crawlers 7 09-22-2011 11:40 AM
need some tire advice RacerScott Losi Mini-Rock Crawler 6 02-23-2010 09:17 PM
tire advice docsbear General Crawlers 10 02-12-2006 11:41 AM
