Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: My motor wires melted together
Old 11-08-2013, 10:56 AM   #1
Default My motor wires melted together
So I have 13 turn 5 slot motors and micro sidewinders. I plugged in a 2000 maah to cell battery and when I press the throttle I saw smoke coming from the back. It was the wires going to the rear motor . They are cheap 18 gauge stranded wires . The insulation melted and the wires touched. What on earth happened?
opek is offline   Reply With Quote
Old 11-08-2013, 11:07 AM   #2
TSK
Shelf queen
TSK's Avatar
Default Re: My motor wires melted together
Too much amp draw from the rear motor? Was there a bind in the rear axle? Any excessive comm or brush wear? The wires were probably shot anyways and just so happened to let go this particular time.
TSK is offline   Reply With Quote
Old 11-08-2013, 11:58 AM   #3
Had the same thing happen to me(twice) an another person it happen too..
Common denominater.. sidewinder micro..
Mine was in a 1.9 and nip when installed. It shot the voltage the other way and desoldered the battery wires from the battery, one time.
The other one melted the wires off the rx wires and motor wires..
I got a new one from castle an traded it, same thing happen to him..
winnerone23 is offline   Reply With Quote
Old 11-08-2013, 01:15 PM   #4
crap. just before this it blew up two batteries.. I assume sending the voltage the wrong way?
the wires were nearly new
Old 11-08-2013, 01:23 PM   #5
some pics
Old 11-08-2013, 04:11 PM   #6
I found out why I destroyed two batteries and melted my wires. Don't build cars the night before a comp...
Old 11-08-2013, 04:14 PM   #7
That's something you only show ur closest friend.. lol....
Not a million ppl and take a pic! :eek:
Old 11-08-2013, 04:19 PM   #8
Haha, it happens. I forgot that I re soldered the whole rig last month and haven't driven it since. I kept saying to myself, "It drove fine last time I used it". That's what I get for being too many bowls, beers, and hours deep when building.
Old 11-08-2013, 06:48 PM   #9
Wire too small for load,loose connections,high amps,stall,binding
JK Krawler is offline   Reply With Quote
Old 11-08-2013, 06:55 PM   #10
Yep...none of those
ittybitty is offline   Reply With Quote
Old 11-08-2013, 07:02 PM   #11
Originally Posted by ittybitty View Post
Yep...none of those
Priceless !
jaloos is offline   Reply With Quote
Old 11-08-2013, 10:06 PM   #12
OK so I fixed up the wires and blammo it doesn't fry batteries or wires anymore. But the rear motor will only drive in reverse... I've ruled out the receiver, the channel, and the transmitter. So it's down to the motor or the esc. The calibration and arming beeps made through the rear motor are a bit muted. The front motor sounds almost like it's in stereo whereas the rear motor/esc combo sounds as if it were in mono. Before I unsolder the ESC and resolder it to the front motor, any input?
Old 11-08-2013, 11:06 PM   #13
The esc acts the same way on 3 different motors. Q_Q Can I break "forward" on the esc from pumping too many amps through it?
Old 11-09-2013, 08:27 AM   #14
It is possible and by the sounds of it more than likely in this case.
Old 11-09-2013, 09:22 AM   #15
Wire too small for load, loose connections, high amps, stall, binding
More like, "Putting both ESC output wires on the same brush hood!"
This equals, "Dead short".
Yep...none of those
The ESC acts the same way on 3 different motors. Q_Q Can I break "forward" on the ESC from pumping too many amps through it?
Too many amps?...... you mean dead short? Yep.
Opek, I will assume that ESC is now fried, time for another one.
May I suggest a new (new pair??) of Holmes mini BR-XL's?????
Charlie-III is offline   Reply With Quote
My motor wires melted together - Similar Threads
Melted stock motor wires turdferguson Axial Wraith 1 02-08-2012 04:34 PM
motor wires hammer_213 Losi Micro-Rock Crawler 4 04-01-2011 10:20 AM
motor wires Mr.Cool Electronics 1 11-22-2008 08:04 AM
Motor Wires rash_powder Tamiya Clod Buster 2 02-02-2007 12:01 AM
Steering motor pulley melted trailrunner General Crawlers 4 05-08-2006 08:23 PM
