11-29-2013, 08:58 PM | #1 |
| JSLICK's DD WIP I had a spare set of axles from my rig two seasons ago just sitting around collecting dust. I have always been interested in the DD chassis ever since I saw Yocci run it at Nats. This will be a fun rig to test and tune. I have been lucky having a club member that ran one last season so he was able to help with the shock set up. I still need to get some goodies for it, that is why it is my WIP project for the winter. A while back I won a body from Lattice Innovations and a Paint Job from BC Paints. So why not put it on. Things still needed are the smashed Holmes BRmini, an axle mounted battery tray, some new VOODOOs and most likely a new servo, the hitec that is on it right now has an ear broken off and I have put it through the ringer for the past two seasons. Last edited by Jslick; 01-17-2014 at 09:55 PM. |
11-29-2013, 11:45 PM | #2 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: JSLICK's DD WIP
Looks like it's going to be fun! I liked running Brian's for sure. Good luck with it slick!
11-30-2013, 12:20 AM | #3 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: JSLICK's DD WIP
Off to a great start. I see you got the Gunnar mount figured out. It looks like it'll work well. |
12-02-2013, 08:43 PM | #4 |
| Re: JSLICK's DD WIP
Got some goodies in the mail today, some more knuckle weights for my DLUX knuckles and an axle mounted battery tray on the way. Now to get a new servo and my Holmes brminis.
12-02-2013, 10:16 PM | #5 |
Rock Stacker Join Date: Jun 2009 Location: Indonesia
| Re: JSLICK's DD WIP
Hello JSlick, what Foam do you use in that rovers front and rear ? Thanks |
12-03-2013, 05:40 AM | #6 |
| Re: JSLICK's DD WIP These are ones I ran sometime ago. They are oldschool CI dual stage soft up front with a firm inners and Med. outers in the rear with firm inners. I will be getting some new VOODOO kicks for this sometime over the winter. I will probally run Golds all the way around. This rig is going to come in on the lighter side, it should be interesting to drive. Like I said this is a back up rig to playaround with. I can't wait to get it on the rocks. |
12-03-2013, 06:46 AM | #7 |
| Re: JSLICK's DD WIP That's exactly what I said about mine, but it quickly turned into my "go to" rig. I'm betting the same thing will happen to you Only things I see right off are that you'll probably want to add some shims or washers to the upper link mounts to keep from pulling the outer ears in. That will keep it from warping and prolong bearing and gear life. I'd like to see a pic of it at full twist...looks like you've probably got quite a bit of travel... Last edited by ittybitty; 12-03-2013 at 06:49 AM. |
12-03-2013, 07:06 AM | #8 | |
| Re: JSLICK's DD WIP Quote:
Thanks, I'll shim them up and get a picture of the flex when I get home tonight. The rear shocks have more travel than the front. AddictedtoRC1 was nice enough to set up the shocks for me the way he ran them on his rig. Last edited by Jslick; 12-03-2013 at 08:24 AM. | |
12-03-2013, 07:32 AM | #9 |
| Re: JSLICK's DD WIP
Ok...I think you'll find that you'll want some limiters in there. Of course since you're still running a rear housing in the rear things will be slightly different. Are you running anything inside the shocks...limiters or "suck down" springs? I'm also partial to Rovers on this rig. Last edited by ittybitty; 12-03-2013 at 07:40 AM. |
12-03-2013, 07:38 AM | #10 |
| Re: JSLICK's DD WIP
Here's a post where you can see my front and rear shocks pretty well...look at the amount of limiters on it Ittybitty's DD XR |
12-03-2013, 08:08 AM | #11 |
| I'll jump in here. The fronts have a spring above the piston and the rears have a short bit of spring under the piston. Basically the way Yoshi has his set up. I did run external limiters on the rear, I just left them off for Slick as his setup would likely be a little different from what I had. I thought it best to let it up to him to decide how much he wanted to go with. :thumbup:
01-17-2014, 09:37 AM | #12 |
| Re: JSLICK's DD WIP |
01-17-2014, 12:27 PM | #13 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
| Re: JSLICK's DD WIP
i saw some different selfmade upper's, but i think your's one of the best. Nice looking |
01-17-2014, 01:42 PM | #14 |
01-17-2014, 03:26 PM | #15 |
| Re: JSLICK's DD WIP Got home today and found a goodie bag from OTTSIX in the mailbox. Got them all washed up and set out to dry. I have some building to do tonight. I am going to try something different with these. I like to run the 6in CI foams. For my other XR I ran GOLDS up front and BLUES in the rear. This time around I am going to give the 5.5in med. up front in the GOLDS with a med. tuning ring and in the rears I am going to run the SILVERS with a 5.5 soft outer with a med. tuning ring. The SILVERS are more forgiving than the GOLDS are in foam tuning. I know the tuning ring will make them taller and get me back to the 6in. height, however I expect them to act a bit differently. Ugh, just checked my rubberized CA and it is all dried out. Have to go pick some up in the morning. Last edited by Jslick; 01-17-2014 at 10:08 PM. |
01-17-2014, 06:40 PM | #16 |
| Re: JSLICK's DD WIP
I'm going to have to get a set of those rings if I'm going to try my DE wheels. Thank you for posting your voodoo tuning info. This is the season I run them all year. I need all the help I can get. This rig is looking really good slick. Very nice!!
01-17-2014, 10:01 PM | #17 |
| Re: JSLICK's DD WIP Last edited by Jslick; 01-17-2014 at 10:09 PM. |
01-18-2014, 04:15 AM | #18 |
Rock Stacker Join Date: Jan 2012 Location: La Verne
Cool body on your dd chassis, haven't seen one like that.
01-18-2014, 05:58 AM | #19 |
01-18-2014, 12:59 PM | #20 |
| Re: JSLICK's DD WIP
Looks REALLY good |
JSLICK's DD WIP - Similar Threads | ||||
my Ridgecrest... (WIP) | doc.hamilton | Axial AX10 2nd-gen | 23 | 11-28-2012 05:25 PM |
JSLICK's Rockthrasher XR10 | Jslick | Paint and Body | 7 | 06-19-2012 11:18 AM |
my new wip (nsfdu) | hairba11 | Tamiya Txt-1 and Juggernaut | 31 | 08-12-2007 12:03 PM |
