01-30-2014, 11:39 AM | #61 | |
| Re: Am I too late to get into XR10 comping? Quote:
01-30-2014, 11:55 AM | #62 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
Yes what Calderwood said There are acouple other guys that used to do them but not sure if they still do like ittybitty or eddie at crawler inovations. The main guy now is Everetty But get in line his line is getting quite long |
01-30-2014, 12:02 PM | #63 | |
Quarry Creeper Join Date: Oct 2013 Location: Skamania County
I just copied a cut pattern I seen here on the forum. I have not shaved the side walls as I don't know how, or what it does yet. That is one of my next projects to figure out. Voodoo's huh? Thanks! | |
01-30-2014, 12:03 PM | #64 | |
I'd be interested in this info as well | |
01-30-2014, 12:07 PM | #65 |
I built a cheepo moa rock crawler using a Redcat RS10 and mounted everything from it to a gmade R1 chassis. (that build is what got me wanting the XR10) Anyway I have a set of rovers on it I guess I should try they might do better, I forgot about that one sitting in the closet. OOPS!
01-30-2014, 12:09 PM | #66 |
| Re: Am I too late to get into XR10 comping? |
01-30-2014, 01:02 PM | #67 |
What size CI foams? 5.25, 5.5"? Soft front, med rear? Red dot compound? Are the pins cut or are they full tread pattern like they come from the store? Pics, we Love pics! |
01-30-2014, 07:49 PM | #68 | |
They are red dots, and the foams are medium front and rear. | |
01-30-2014, 07:50 PM | #69 |
Calderwood: I did check out that post, those are awesome looking tires. So how do you "shave" the side walls? Does that help the tire flex better?
01-30-2014, 07:51 PM | #70 |
Whoah! Crawl-o-Matic I was on your website today looking at your tires. I was refereed through these guys here. I think I am going to get a set.
01-30-2014, 08:39 PM | #71 |
They should work good. With med up front, you should really shave the side walls or atleast cut the side lugs off. Most used way is a dremel with a sanding drum. Make some nice even strokes till they are smooth. You will be pretty amazed at how it "wakes" the tire up! |
01-31-2014, 07:49 AM | #72 |
Okay, I was wondering exactly how they shaved them. Yeah I'll try that. In the mean time I bought a set of HPI rock grabbers for a great deal on eBay, and I am going to get a set of Voodoo's too!
01-31-2014, 10:29 AM | #73 |
Absolutely nothing wrong with having choices on shoes! Its definitely part of the fun, learning, and tuning.. |
01-31-2014, 02:51 PM | #74 | |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
VooDoos are an awesome tire. Im running silvers with 6" CI DD foams with soft up front and med in the rear. My rig weighs about 4.5 pounds too though. IMO the 5.5's are too small and make the tire too soft. You need the tire a little firmer to make them pins work | |
01-31-2014, 03:25 PM | #75 | |
RCC Addict Join Date: Oct 2009 Location: San Francisco
For those wonder cut n shut means you enlarge or shrink a tire or even change sidewalls and treads. It takes some skill and a LOT of patience but the results you can get are amazing. If you need inserts I use these McMaster-Carr (94510A030) they are invaluable! Just make sure you drill in the center of the hole or you will have a few locating problems! Other than that just get out there and drive your rig. The best advice I got was try and do lines you THINK you can't pull off and learn from your rig what it can and can't do... then adjust accordingly. | |
01-31-2014, 03:52 PM | #76 | |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
But yes like Calvin Said it basically cutting tires to make them different... Say if you want to make a tire narrower you cut out a section in the middle and glue the 2 sides back together... or if you want to make like a 1.9 tire into a 2.2 you cut the 1.9 tires glue in another section and glue in 2.2 sidewalls... | |
02-01-2014, 12:40 PM | #77 |
Whew that sounds a little intimidating. I could definitely see the benefits of the whole cut & shut. I think I would like to get the shaved side wall a try however. I have 90 degree pneumatic grinder that I think would be perfect, its right in between a 4" and a dremel. Everetty's work is rather amazing, they don't even look like they have been altered. So I think I am going to 1 - Shave my boss claws 2 - Get a set of Voodoo silvers I picked up a set of HPI Rock Grabbers and some cheep-o beadlock rims off eBay yesterday for $25 bucks, I couldn't help myself, just like Winnerone23 said "nothing wrong with more shoes!" I built a solid metal SCX10 (the pic in my avatar) and here ( Project Heavy Metal SCX10 w/o any Axial parts ) I really want to run the set of these awesome black and chrome aluminum 1.9 rims, and I can't find a tire big enough for a 1.9 to fill in the fender wells. This could very well be my solution, but damn this is one of those 'needs lots of experience' jobs to make it look right. |
02-05-2014, 07:43 AM | #78 |
Hey I just really wanted to say again that you guys kick ass. Your help and suggestions help me to push on and get another XR10 out comping again. Fortunately I did have a great platform to start with, when I bought the XR it came with: Tekin FXR Pro Punk Dig Hitec 7950 CC BEC Brood 35T motors Heavy Axial aluminum Links Carbon Fiber Chassis VP aluminum hubs Axial aluminum C's, and chubs Axial HD Motor plate Since I bought it I have bought: VP SLW Rims (waiting on different hubs to come in still can be seen in pic 1) VP Brass Weights VP Servo Gaurd New Axle housings f/r RC4WD Hardened Gears f/r CI 5.5" Foams soft/med A multitude of Tires. I am going to start with the HPI Rock Grabbers. I will upload new pics when I get the rims put on. I have a new chassis sitting at home, but I got a great deal (here on the forum) for a used BJ4 that I can get warmed up with and beat the tar out of for awhile. I still have to the my shock situation sorted out, I know that everybody is running the Traxxas shocks, but I have been curios about these --> 2x Spark Comp Shock with Ti Shaft (110mm) andybody have any experience with them?I have decided to get the Dual HH BR mini's, and the Crawlmaster HH motors. Those will be purchased later on. Between the last 2 days after work I have been tearing down the XR10 and getting it all 'stuffed' into the BJ4. I have more work to do but figured your guys insperation should have a bit of payoff for your efforts by proof in the pudding pictures of a new mildly built comp XR10, the first picture is what it was when I bought it, then the other 2 I took last night, it currently weighs in at 6.172943 lbs RTR so there's some weight to be lost yet. Thanks again fella's |
02-05-2014, 11:25 AM | #79 |
RCC Addict Join Date: May 2012 Location: Folsom
Lookin good man
02-05-2014, 11:32 AM | #80 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
Looks like your coming along very nicely!!! Sorry have no experience with those shocks but I would go with the traxxas big bores or the scx10 shocks. Both will work very well for you. Now get out on the rocks and see how that rig will do!!!
Am I too late to get into XR10 comping? - Similar Threads | ||||
How many are still comping...... | brettd | Axial XR10 | 14 | 02-05-2013 09:21 AM |
anyone comping 1.9 anymore | metalking | Losi Mini-Rock Crawler | 2 | 11-15-2012 10:42 AM |
Getting into comping. New XR10 | neoakaj | Axial XR10 | 11 | 11-08-2011 10:42 AM |
XR-10 or AX-10 for comping | minnesotamudder | Newbie General | 20 | 09-01-2010 08:15 PM |
Comping w/ R1 (anyone) | snwchris | G-Made Crawlers | 6 | 08-06-2010 12:42 PM |
