04-23-2014, 11:16 PM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| compression legth?
Hello. I'm building a new chassis and I Have a problem.....when I compress the chassis the total length of the car is almost 1cm bigger than with no compression. Is this ok? Am I building some thing wrong? Thank you |
04-24-2014, 01:12 PM | #2 |
| Re: compression legth?
Yeah that sounds normal. Having equal length upper and lower links helps to combat this effect. Most rigs out there will "probably" have more of a difference than that from full compression to full droop. |
compression legth? - Similar Threads | ||||
Suspension droop Vs compression (AX10) | Mud Puppy | Newbie General | 13 | 10-22-2010 10:23 PM |
Axial Suspension--Droop/Compression | tanmonster | Axial AX-10 Scorpion | 13 | 10-10-2008 08:10 PM |
Suspension compression winch on the WK | Locked Up | HPI Wheely King | 6 | 02-17-2008 11:38 PM |
