Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Robbobs Not reinventing the wheel ........
Old 02-26-2015, 05:48 PM   #41
Default Re: Robbobs Not reinventing the wheel ........
I am also in for 2 of those motorplates ;)
markusgabl is offline   Reply With Quote
Old 02-26-2015, 06:16 PM   #42
Custom Carbon Fiber
Robbob's Avatar
So the other night I had some motivation to do some work and I chose the one thing I hate MOST about RC cars ...... Shocks. I absolutely despise working on shocks. Messy, air bubbles, messy, oil, bleeding ... rebleeding ..... just a mess. Ok so anyway heres where I started.
I have to say thank you baby jesus someone picked up Eggressors delrin shocks! I loved these things when I had my other trucks and so happy RcBros picked them up, as well as some other goodies Ill show later.
And as you can see I got some shock shafts too. Again to recap and save some of you from digging Ill mention why I use these Traxxas shafts. First I dont like internally limiting shocks. Just to much to change a limiter and it doesnt stop the shaft from pushing into the bladders if they fully compress. The Traxxas 1664T shafts are bit shorter and help with this. Also since we use the Traxxas big bore orings these fit better helping prevent leakage down bottom. Again all my opinion.
SCX Shaft
Traxxas 1664T
Little weight comparison of a built SCX body vs a built Delrin body
Now I plan on running external limiters of 6mm .... so building these I used a SpecR shock tool that helps set rebound in touring cars. I used the 5mm setting.
Torture done
Now onto some pictures of the fun stuff ..... Another high five to a vendor on here. New bearings both stock and VP big sized
With those I was able to get an axle started .... now if my screws just get here quicker
Did my bushing/delrin trick again ..... let me save you some digging again. I made this bushing out of delrin years ago to combat the bushing/bearing issue and blowing gears. The delrin has a sleeve on it that (I believe) helps support the Ti shaft. Yes Ti is lighter then steel and stronger BUT its will bend. Under the loads I felt the top shaft had some deflection and that was a cause of gears popping. I never did the 2 bolt mod on my truck but never had a gear pop or blow up from doing this.
And going together ........ Yes plastic housings Told ya I wanted a skinny chick rig.
Ok thats its for now ...... thanks for looking ......
Robbob is offline   Reply With Quote
Old 02-26-2015, 06:51 PM   #43
Looks good if ur works out I'm thinking about the stock plastics ones I've got the VP ones but hate the color loving that people haven't forgot the xr guys....
cliff1119 is offline   Reply With Quote
Old 02-26-2015, 07:59 PM   #44
I don't have a XR anymore, but that dual delrin bushing under the link mount looks Way better then any other option I ever saw!
Good stuff!
winnerone23 is offline   Reply With Quote
Old 02-26-2015, 08:06 PM   #45
Custom Carbon Fiber
Robbob's Avatar
Good stuff!
I ran an entire season with them both front and rear in my XR when she was just under 4lbs ..... 2 years ago lol
Old 02-26-2015, 08:23 PM   #46
Are you using RC4WD gears. Nice motor plates.
SDheavymetal is offline   Reply With Quote
Old 02-26-2015, 08:34 PM   #47
Custom Carbon Fiber
Robbob's Avatar
The spool is RC4wd but the other gears are Hot Racing.
Thank you.
Old 02-27-2015, 05:24 PM   #48
Custom Carbon Fiber
Robbob's Avatar
Mission 1 completed .... I actually have a functional axle.
From
To
Yes - ForEveeeeeeeeer ........... Multitasking
Old 02-27-2015, 05:44 PM   #49
looking great hope to see it on the rocks soon.
desertrob is offline   Reply With Quote
Old 02-28-2015, 05:14 AM   #50
Custom Carbon Fiber
Robbob's Avatar
Thanks ... me too if the snow ever melts up here.
Old 02-28-2015, 07:19 AM   #51
Ha! Their forecasting another 3-6 inches for sunday\monday
crawlinghulls is offline   Reply With Quote
Old 03-02-2015, 11:33 PM   #52
its going to be a close race with the weights between us this should be interesting to follow
Purptr8r is offline   Reply With Quote
Old 03-03-2015, 05:57 AM   #53
Custom Carbon Fiber
Robbob's Avatar
Youll probably get there before me lol ....... between the USPS and machine time it took me a 2 weeks to get my rear axle built and the fronts only half way together.
Old 03-03-2015, 06:19 AM   #54
Interesting build like the detail and enthusiasm keep up the good work and pictures.
Artarie is offline   Reply With Quote
Old 03-03-2015, 11:50 AM   #55
I'm not a machinist I do all my own stuff and I've been working on these axles for weeks so it is a slow process
Old 03-03-2015, 12:27 PM   #56
Custom Carbon Fiber
Robbob's Avatar
I'm not a machinist
Me neither .... I turn knobs and duck for cover.
Old 03-03-2015, 01:03 PM   #57
63 grams off the axle, that is some serious weight savings. Keep it up. That's more than .25lbs if you pull that off on both the front and the back.
BC-Brian is offline   Reply With Quote
Old 03-04-2015, 08:21 PM   #58
Custom Carbon Fiber
Robbob's Avatar
Forevvvvvvver ....... spent a couple hours down in the hole the other night and made this.
Kind of liking the new toy a lot ......
Also made some extras if anyone just wants the mount instead of having to buy all the pieces. You can check them out in the Vendors area.
Hoping the rest of my front end stuff and links come in by Friday so I can maybe have a roller. And some more good things to add to the Vendor area.
Old 03-04-2015, 08:52 PM   #59
Oh you fancy braaaahhhhh
Old 03-04-2015, 09:36 PM   #60
Nice.
Im jelly, gotta get my Ti shafts in and see if I can match you.
Multi...pass?
Morbid Angel is offline   Reply With Quote
Robbobs Not reinventing the wheel ........ - Similar Threads
Robbobs next level of scale Tundra style Robbob 1.9 Scale Rigs 100 01-28-2016 01:00 PM
Reinventing my AX10...(again) Sucker Punch Chassis time. Master Basher Axial AX-10 Scorpion 70 08-13-2014 08:58 AM
Robbobs LCC Robbob Team Losi Comp Crawler 216 09-09-2011 11:32 AM
