02-26-2015, 06:48 PM | #1 |
Rock Stacker Join Date: Feb 2015 Location: ITALY
| PREDATOR xr10
Hello everyone, I present my predator 10 I just bought these new axles, and sold those of the berg v1. currently possess only rockstar custom chassis 2 esc sidewinder with bec cc 4 dampers scx 10 modified and 2 axles xr 10 vanquish. accept advice on where and what parts to buy.. ENGINES RIMS TYRES SPONGES soon be ordering the links always markus and I also believe carbon rims |
02-27-2015, 01:57 AM | #2 |
Rock Crawler Join Date: Jul 2013 Location: Manchester
| PREDATOR xr10
Daaaaaammmmmnnnnn n son look at those axles where did you find them ;) must have been PURPMART Sent from my iPhone using Tapatalk |
02-27-2015, 10:59 AM | #3 |
| Re: PREDATOR xr10
I chose the colors and components,and had them mounted with a friend.... ;)
03-04-2015, 12:06 AM | #4 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodų city
| Re: PREDATOR xr10
engines???? I know from expirience that HolmesHobbies have some great motors.. Like the HH Pullers, Or the cheaper option is HH Tourqemaster Pro, not over 35T. 30 or 35T on the motors,the 45 and 55 is just to damn slow. Or the other option is team brood motors,,here there are also a few to choose from,,the conflux is very popular, these motors you build them youreself on the website to team brood, here there are 1000 off different things you can choose to have on youre motors so you get em 100% the way YOU want em to be.. or maby the Nexus,,his replacement for his stubby motor.. also a well used motor.. About the tires, why dont use the rovers you have on the axels??? Great tire. or do like 90% off the rest and buy the ottsix voodoos from crawlerinnovation,and buy the dobble deuce foam while you are shopping for tires,,there are combos depending on the RTR weight off youre rig.. |
03-04-2015, 08:35 AM | #5 |
Rock Stacker Join Date: Jan 2015 Location: Boone
| Re: PREDATOR xr10
Sick! I am working on a Honey Badger Mantis. Was either going to do Predator or Honey Badger. Glad I didn't steal your thunder. Going to run 35t Tekin pros.
03-04-2015, 09:00 AM | #6 |
| Re: PREDATOR xr10
I'm thinking at the end to save on engines, and take in the wake of HH as you seem the Integy 35t double bearing? while for the tires I found 4 voodoo complete circles and sponges used.. |
08-06-2015, 06:06 PM | #7 |
| Re: PREDATOR xr10
My Predator in progress!! FANTASTIC PRO CHASSIS |
08-06-2015, 06:15 PM | #8 |
| Re: PREDATOR xr10
PT 2 mounting!! |
08-06-2015, 06:19 PM | #9 |
| Re: PREDATOR xr10
The latest purchases for the moment ;D I look forward to your advice and your opinions |
08-06-2015, 06:36 PM | #10 |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: PREDATOR xr10
Great chassis choice. |
08-06-2015, 06:37 PM | #11 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: PREDATOR xr10
Check with Robbob (Crazed Builds) for a taller rear link mount. It'll give you more clearance for the rear motor and also let you clock the rear axle up a bit for additional ground clearance.
08-07-2015, 10:10 AM | #12 |
| Re: PREDATOR xr10
Thanks solitaire I miss just the rear link mount,weight and weight holder,I saw one of robbob but I live in Italy, I wanted to find a solution less expensive and faster
08-12-2015, 08:38 AM | #13 |
| Re: PREDATOR xr10
if you plan on running with the motors/gearcases so low I would buy some motor saver`s/ motor guards..' check with winnerone23,, he makes in carbonfiber,, or else you have BWD motor saver for 8$,, you can find them on Holmeshobbies.com... |
08-12-2015, 08:41 AM | #14 |
| Re: PREDATOR xr10
BTW,, it is a good thing to have the rear motor so low,, it is alot off weight on the xr10 axels, and when clocking them up mutch to get more clearence you will have unwanted weight higher then you need |
10-15-2015, 08:45 PM | #15 |
| Re: PREDATOR xr10
Some pictures of my predator on action There are several things that should be placed, but to be early works divinely Good vision Last edited by Castrol92; 02-06-2016 at 01:53 PM. |
10-16-2015, 12:38 PM | #16 |
| Re: PREDATOR xr10 |
10-17-2015, 03:07 AM | #17 |
Newbie Join Date: Aug 2011 Location: italy
| Re: PREDATOR xr10
looks good! what's on the rear? I can see a strange upper link mount |
10-17-2015, 05:53 AM | #18 |
| Re: PREDATOR xr10
Castro, your going to love the Remedy chassis its just so willing to perform. I'm sure you've seen MENERGY's build information, it has lots of critical set-up tips? He uses the stock XR10 upper link mounts and they work great with the design and are the best performing option IMO. Looking good, love the color combination. Nom |
10-17-2015, 05:56 PM | #19 | |
| Re: PREDATOR xr10 Quote:
Thank you so much, I tried some different settings and I must say this has proved one of the best,the only bad aspect was that on 90° of gradient he worked in negative and he rolls,but just got home I moved one hole the rear dampers with less inclination I will let you know in the next test if it works better | |
10-17-2015, 05:59 PM | #20 |
| Re: PREDATOR xr10
The rear link mount is a temporary solution created by me,he is made of aluminum does not have great looks but weighs very little |
PREDATOR xr10 - Similar Threads | ||||
Predator Tracks | rubiconrockkrawler | Scale Comp Rules | 1 | 08-17-2012 07:54 AM |
Predator vs Terminator?????? | Frankenwheely | Chit Chat | 35 | 07-24-2012 08:26 AM |
The Predator 6x6 | diantae | Multi Axle Rigs | 10 | 07-19-2011 06:29 AM |
Predator V2 | jetboat | HPI Wheely King | 14 | 09-11-2008 05:28 PM |
