03-03-2015, 01:09 PM | #1 |
Newbie Join Date: Feb 2015 Location: Madison
| xr-10 aluminum axle case
my one know where to find aluminum axle case for xr-10??
03-03-2015, 05:30 PM | #2 |
Rock Crawler Join Date: Jul 2013 Location: Manchester
| Re: xr-10 aluminum axle case
You really don't want the axle case to be aluminum ... It's very heavy ... The transmission cases are made by vp and hot racing .. The hot racing ones are lighter and come with larger bearings like the vp ones ... The vp ones are hard to find I have a few if you're looking Sent from my iPhone using Tapatalk |
03-03-2015, 11:42 PM | #3 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
but if you want a sexy crawler the vp-stuff is a must.. he he he.. |
03-04-2015, 09:39 AM | #4 |
Sexy shouldn't matter .... Weight and performance means more than sexy Sent from my iPhone using Tapatalk |
03-04-2015, 10:49 AM | #5 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: xr-10 aluminum axle case |
03-05-2015, 08:04 AM | #6 | |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| Re: xr-10 aluminum axle case Quote:
03-05-2015, 08:19 AM | #7 |
mine xr10 reptile is 1880g,that is with 50g on each knuckle,so it`s 100g just in brass, but that weight was before I got the alutops from vp and the linkmounts also from vp,,I used the calderwood design carbonfiber linkmount and are very happy with that... I have not compared the weight off the alutops vs the stock plastic ones,but I`ll guess they are maby 4-50g more each vp-top.. but I will still end up under 2kg with 100g on the knuckles and that is with ALL the vanquish parts that ever have been made.. |
03-05-2015, 11:29 AM | #8 | |
My ready to run weight with batteries and knuckle weight is just over 3 pounds ..... So almost a pound lighter than you I have delrin cases so I have big bearings as well ... There's no real benefit to the aluminum top other than looks ....if you're afraid of the small gear shaft bearing swap to brass if you're heavy and pop gears do the screw mod ... You don't need an Aluminum axle to mount shocks to lol shocks absorb impact ..... Sent from my iPhone using Tapatalk | |
03-21-2015, 07:40 PM | #9 |
Rock Stacker Join Date: Dec 2011 Location: Coaldale
I guess I should weigh mine and see what its at. it has a lot of upgrades also
xr-10 aluminum axle case - Similar Threads | ||||
Aluminum Axle case | Leland915 | Tamiya TLT Crawlers | 61 | 11-02-2006 05:02 PM |
