06-05-2015, 05:02 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: Under a Rock
| BarryBelvedere's XR-10 RE-Build w/ The NEW AMX Chassis!!! BarryBelvedere's XR-10 RE-Built Thread with The New AMX Chassis!!! |
06-05-2015, 06:51 PM | #2 |
| Re: BarryBelvedere's XR-10 RE-Build w/ The NEW AMX Chassis!!! Parts List.... +Barry's R/C Carbon NEW!!! "AMX" 2.2pro Chassis +Barry's R/C Carbon fiber MOA Motor guards +Barry's R/C Carbon XR-10/ Hitec 7980 3mm thick Servo Mount +Barry's R/C Carbon Steering arms 3mm thick +Barry's R/C Carbon Knuckle weight lowering kit "Hung lo" +Vanquish Motor plates +VP Gear box bushings F&R +VP Front axle top +VP Wraith Knuckles +VP Front axle 4-link mount +VP rear axle 4-link mount +Vp Hubs in the front +Shift hubs in the rear +DLUX Wheel faces,inner rings & spacers +DLUX 1/8" & 1/4" wheel spacers for width tuning +Crawler Innovations foams 5 3/4" soft in the front & 5 3/4 med in the rear, closed cell inner +Axial XR-10 plastic axle housings and gear cases +Axial hard/Light Gears F&R +Axial chubs +RCBROS Knuckle weights and Holders +Rowdy Racing Battery, Electronics mount and servo guard +Jeepindoug spring retainers +Kyosho velvet blue cap 3.75" shocks w/Cap mod +Losi mini-t springs pink in the front & orange in the rear +Lundsford TI. Rockgrinder links +Traxxas #5525R heavy duty (Jato/slayer) rod ends x18pcs. +Traxxas #5347 Revo Rod ends x2 +Voodoo's silver pin tires & or depending on situation HB Rovers if it rains! Electronics + Holmes Hobbies 5 pole 13t skewed Motors matched for an XR-10 x2 +Castle Creations Micro Sidewinders x2 smashed together +Castle Creations BEC set at 8.0 volts +Hitec 7980 servo w/ aluminum plate mount (custom) +Futaba 3pk superw/ Max amps Tx Li-po +Hobby King Frsky TFr4 reciever +Hobby King Turnigy 3 cell li-po 800mah & 550mah Last edited by barrybelvedere; 03-18-2016 at 03:57 PM. |
06-05-2015, 07:12 PM | #3 |
Rock Crawler Join Date: Jun 2012 Location: jville
Looks interesting barry ill be watching forsure
06-05-2015, 07:18 PM | #4 |
Pebble Pounder Join Date: Sep 2008 Location: Vancouver Island, BC, Canada
digging the rover shave. Just did a set last night almost the same. Kept the small vertical lugs on, on the front inner sidewalls. Havnt tested them out much but should be gtg. Havnt seen those Kyosho shocks before they look good. Interested in seeing the knuckle weight lowering kit of yours. |
06-05-2015, 08:04 PM | #5 |
I just received a Chrysler minivan and an Escalade to detail. I will be busy till some time tomorrow. I would rather be finishing this re-build, new chassis thread.
06-05-2015, 09:08 PM | #6 |
RCC Addict Join Date: Aug 2009 Location: Earth?
More pics!
06-06-2015, 12:32 AM | #7 |
Ok..Kbrog! More tomorrow...
06-06-2015, 01:59 AM | #8 |
Rock Crawler Join Date: Feb 2014 Location: ?
IMO shaved Rovers will always be cool. That's a sexy chassis. Great to see the XR10 getting some love.
06-06-2015, 11:46 AM | #9 |
Chassis by...
06-06-2015, 12:02 PM | #10 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
Great chassis.. I am crazy about the 2.2pro bodyless carbonfiber chassises.. I have 4,, soon 5.. Cant sell my chassises,, I am sort off collecting 2.2pro chassis. and always when there is a new chassis I am very happy. Do you make youre own links to this chassis.. I also run the velvet kyosho shocks,,and I love them,,so smooth and 100% leakproof.. |
06-06-2015, 12:07 PM | #11 |
PS,, did read that you have youre BEC at 8.4V and you are using the 7980 servo,, I also have the 7980 but hitec say it only can handle 7.4V..
06-06-2015, 03:31 PM | #12 |
Yeah i am aware of this Mr. Floki.... I am a maniac! Says Stormin2U, and I like to push my luck in the search for ridiculous performance! I have been running it like this for a more than a year now...At that voltage! i have ripped the servo clean off the front axle 5 times now...I no longer have this issue and all will see why soon.
06-06-2015, 05:04 PM | #13 |
The Idea behind this chassis is so that anybody running a T1E , Y-town or any other similar style chassis can re-use their existing links ( I used my DD links but had to use long ass Jato rod ends all the way around instead of the short Revo ends)and just switch to a newer, better &lighter chassis where replacement parts can be acquired. I broke my sniper so I bet there are others out there that have broken cabs. I have been using My Yoshi DD Chassis for two years and it would pull lines that NO other rig could wish of doing. But it was unpredictable is some cases, with no warning at all it would start flopping onto its top like a dying fish. And I managed to break the top and middle plate at different times. The DD is most likely THE lightest possible chassis ever made! I believe with hardware it was about 52 grams. The AMX is around 74 grams. The Y-town BJ4 is about 99 grams. I decided to create my own chassis after wanting to buy a Remedy 3.5 and I realized I have all the Carbon, standoffs & hardware right here in front of me. The only dilemma was...Do I start from scratch and think outside the box like Yoshi did or do i str8 up copy someone else's idea. So I made a modified version of the CCC boxer for my 2.2 sporty with some minor changes like the gearbox mounting holes are 4mm shifted forward, Its made from 2.5mm thick carbon, The lower link screws are countersunk, The lower link spacing is the same but the chassis width is narrower by 3mm on each side, Added body mount holes toward the rear because i dislike the way the post never stays where you want it and the bottom edges of it have a 45 degree angle. That was sort of my practice re-design chassis. It works TITs! Credit goes to the other carbon cutting Barry. My Boxer re-make will stay a one of a kind because it is wayyyy to similar to CCC's Design. I will not be making any more like it! The AMX was going to be called the AMC because it's kinda All Makes Combined, But Beest and I thought that AMX sounded better and I can continue with more designs named after bad ass muscle cars. When looking at the AMX you can pick out all the good ideas from 5 different modern highly preforming chassis put into one design. I finished cutting it out by hand a week b4 ECC! It was set up with no testing 3 days before i drove 19 hours to Alabama For ECC. I had no idea if it would be crap! To my surprise it is awesome, super predictable & easily pulled great lines. I had a wire rip off my deans plug while upside down on the 3rd course of the day trying to flip myself back over so I had a crap score on course 3. I finished 3rd in 2.2pro behind BTF 1st and Winner123 2nd. When we ran the finals course gate 4 with the 60ft cliff a foot behind the climb! If you rolled over backwards trying gate 4...Well Beest found out the hard way and his Berg went byebye. BTF and winner123's rig wanted nothing to do with the wet small but technical climb which would have been easy in the dry. This Rig was the ONLY one to finish the finals course that day with 1 of 4 bonuses. There was 2 seconds left on the timer at the end. It was an epic run I wish it was on vid! Some pics were taken by Purp with my phone but 50% of the pics my rig was a blurr! I Used mostly horsepower to blast in the air thru 5 of the gates Dukes of Hazzard style. The only gate i hit was like maybe gate 7? and i didn't have much of a choice...I know it was possible to not hit it but time was the enemy not points. Fishmaxx set up a great finals course! For thoes who missed 2015 ECC it was your loss! Be there next year! Last edited by barrybelvedere; 06-06-2015 at 05:18 PM. |
06-06-2015, 06:10 PM | #14 |
I spent about 5 hours drawing up the new design. I drew up 10 different chassis, some of then looked soooo stupid i destroyed all evidence and pics because some were retarded looking. Although my link & shock positions were all the same from one to the next, I knew where they had to be, Cant really compromise on that! Its alot harder than it looks to draw up something good looking that hasn't already been done unless you combine all the good aspects into one. I have AMX#1 on my XR-10. Beest is in possession of AMX#2 He will be doing a build thread with Berg axles as soon as he gets away from working on his Dodge Diesel.... AMX#3 is pictured here...It will be the first AMX To be sold on RCCrawler.com These will be less expensive than most other chassis! P.M. Me if you would like to get it before These are put in the Vendors chassis section. Skid and body panels are to be made out of lexan to keep the weight down. Remember... These are all hand cut off of a steel template. Not CNC cut. Not all are exactly the same but soo damn close you can't tell. Anybody who orders AMX#3...If for some reason you break a plate within the first 3 months. P.M. Me and I will get another one out to you as a warranty replacement after that they are $20.00 each. The Team Brood background is only there because it looks good. The only Brood motor I have/run is in my 1.9 mini. I run H.H. in my pro rig Chassis Measurements-------8 3/16" long-----3 3/16" tall-----3" wide------ Lower Link separation 32mm Lower link spacing from front to rear 40mm center of eye to eye Upper link spacing from front to rear 43mm, 36mm or 31mm....adjustability. Last edited by barrybelvedere; 06-07-2015 at 11:28 PM. |
06-06-2015, 06:35 PM | #15 | |
| Re: BarryBelvedere's XR-10 RE-Build w/ The NEW AMX Chassis!!! Quote:
"Our rigs wanted nothing to do with..." Hmmm, seems I remember making gate 4 clean? It took a little time tho :/ Tires might of not wanted it. As BTF and myself where running BC's, but I talked mine into it! ;) However, I will take Zero credit away from your drive skills or your Nothing to Lose, bad assness on that finals course! You drove your heart out and that's all that matters! At FLOKI.. I also run all my 7950's, 7980's, and HH servo's at 8.4v.. Or did.. I bumped my 7980's back to 8.2v, because of the hours of drive time I put on them, on days that I have time to practice.. I'm not sure if it's the 8.4v's or strain I put on them, but I've had to send a few back for repair.. (Then again, I've bought all of them used to begin with. Not knowing how the OG owner treated them) ;) Last edited by winnerone23; 06-06-2015 at 08:52 PM. | |
06-06-2015, 07:10 PM | #16 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
Looking good bub. I'm getting my tools and shop ready to start my build! All prepped. Last edited by Beest; 06-06-2015 at 07:15 PM. |
06-06-2015, 10:53 PM | #17 |
Nice beer!
06-06-2015, 10:56 PM | #18 |
Mmmm beeer.
06-07-2015, 01:51 AM | #19 |
LITE BEER??? No way... That is like drinking Zero coke.... |
06-07-2015, 06:53 AM | #20 |
| Re: BarryBelvedere's XR-10 RE-Build w/ The NEW AMX Chassis!!! |
BarryBelvedere's XR-10 RE-Build w/ The NEW AMX Chassis!!! - Similar Threads | ||||
~TSS~ SCXHR Chassis Build & Info: Performance Chassis Upgrade | STANG KILLA SS | Axial SCX-10 | 87 | 09-12-2017 05:52 AM |
if you could build it what chassis? | warriorsimi | General Scale Talk | 21 | 04-03-2012 10:12 PM |
What new chassis and build would you do?? | Desert Rc | General Scale Talk | 4 | 09-01-2010 03:22 PM |
next build chassis? | Dickie691986 | Newbie General | 3 | 08-08-2008 12:14 AM |
build my own chassis | beerguy | Newbie General | 4 | 10-01-2006 04:49 AM |
