04-19-2016, 07:23 AM | #1 |
| FBA axle shafts - XR length – Dlux
These have gone through testing and not a peep out of them. They have held up rock solid! These axle shafts are to fit a Berg (with the Missing Link Locker) or Axial XR10. Made from heat treated 4340 which is some of the best grade steel around. I then zinc coated them to protect them from the elements. The 4340 shafts will come with either the stock Axial stub (Wraith/XR style) or the 8mm stub version. You will need knuckles to match the stub shaft. If youre running the Axial version, either a XR or Wraith knuckle is needed. If youre running the 8mm stub version, you will need knuckles that accommodate 8mm stub shafts (such as the Dlux knuckles). These universal shafts are capable of approx 70* of steering. These shafts are virtually identical to the Axial shafts except I added material everywhere I could get away with. The inner shafts are no longer sloppy like the stock ones for this reason. There is only one big problem with these shafts. The problem is that they are so expensive for me to produce that I cannot order as many as I think we will need all in one shot so, if you think you want these, grab them while you can. As soon as I start running low, I will order more but it will be close to 2-3 months from me ordering till they are back on the market. Group buys and dealers welcome when purchasing 5 sets or more. Last edited by Erik D_lux; 04-19-2016 at 08:16 AM. |
FBA axle shafts - XR length – Dlux - Similar Threads | ||||
FBA axle shafts - XR length – Dlux | Erik D_lux | EnRoute Berg | 42 | 05-12-2016 07:24 PM |
