07-27-2016, 12:10 PM | #1 |
Rock Stacker Join Date: Jun 2016 Location: portland
| Xr10 build few issues
So I've been talking with Holmes hobbies and losi kid to help get some things ironed out. Both have been very helpful while some of the technical aspects may be a little above my pay grade I am slowly working my way threw things. I have gotten to a point now where it's almost 100 percent driveable and I can learn the small tuning and functions of all my electronics as I go. I have a contracted losikid and hh on this same problem but I thought I would throw it out to everyone who has built xr10 to see if maybe you have had similar issues and there is some information in the grey area between the whole system that is not directly associated with the tx or the esc's. I using stock gearing with 14t hh torque master expert motors with a14t pinion, using a hh dual mini esc, cc bec and a hacked flysky tx/rx. The bec is connected to the battery lead off the esc and plugged into the acc channel on the fx the esc's are connected to channel 2&3 with red wire removed. I reset the tx and re calibrated the esc's. Not sure if calibration was done 100 percent correct but I believe it was. The problem I am having now is witwork fwd throttle the front motor starts to spin before the rear and seems to spin at a slightly faster rate, with rev throttle the rear motor starts to spin first and totems at a much faster rate than the front. I have not changed any rates or trims on the tx as of yet. There is my sorry novel. Thanks for any help you may have
07-27-2016, 01:37 PM | #2 |
| Re: Xr10 build few issues
Do you calibrate the ESC's one at a time .... plug one into the RX and the other unplugged then switch them around Or do you calibrate them both at the same time .... plug battery and both ESC's come one then calibrate I know nothing about the Flysky radios so Im no help on mixing settings or EPA's. Have you played with any Expo settings though for either channel? |
07-27-2016, 01:41 PM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
sounds like he did them at the same time...
07-27-2016, 03:49 PM | #4 |
So as far as calibration goes I've done a little bit of everything trying to get them to work and messing with the tx at the same time must have really had things out of order so after I reset the tx I then tried the calibration process again. I believe the process went correctly as everything went as hh list in the instructions other than the final step in neutral. Directions say all lights well go out which was not the case caught remeber what color but one stayed on on each esc. I did each esc separately out of channel 2 first the front and then the rear. Each esc responded the same threw the process. This is what got me to the point I am at now. But I have tried since then to calibrate them at the same time thinking they may be calibrated but just out of sync with each other. But that just resulted in the rear esc not arming itself thus no power to the rear. So I went back and did them individually again. I haven't messed with to many settings on the tx because I am still learning and trying to understand what all the code and language are on the flysky as it is new to me. Messing with too many things on it for me into trouble in three first place so I'm trying to keep as simple as possible for now
07-27-2016, 08:42 PM | #5 |
I wanna be Dave Join Date: Dec 2006 Location: here
Wish I knew more about flysky radio set-up... have you tried searching YouTube for flysky moa/duel esc set-up?
07-27-2016, 08:57 PM | #6 |
Have you checked to make sure radio is set to neutral or 0 in throttle adjustment.
07-27-2016, 09:00 PM | #7 |
Have you checked timing on the motors?
07-27-2016, 10:41 PM | #8 |
Not sure on timing. How do you figure out if there is different timing
07-27-2016, 10:48 PM | #9 |
Pm sent
07-27-2016, 11:11 PM | #10 |
| Re: Xr10 build few issues https://youtu.be/zJd-cIBhs6E Maybe this will help? Good video on setting up your radio... 8min point is your radio programmed like this guys in video? Last edited by tapped-out; 07-27-2016 at 11:19 PM. |
07-28-2016, 05:17 AM | #11 | ||
| Re: Xr10 build few issues Quote:
Try calibrating one of them in the secondary/aux port that its plugged into when you go to drive it. It needs to be set to that channels settings. Maybe reset the TX again and try it that way? Do them both separately though. Can you see on the screen anything that shows the throttle input changing? Like numbers or a slide bar for both the throttle and aux channel? On our MT4's we can see a slide bar move forward and backwards when you pull our triggers. We can see if they are equal or stalled back. | ||
07-28-2016, 09:35 AM | #12 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
You have the same issues I have....just a slight delay in the motor sequence (one starts before the other...I believe mine is the rear motor though). It's been awhile since I plugged it in. I thought it was motor timing but my HH 13t do the same thing. Running duel FXRs smashed and programmed by Heyok. He supplied the GT3c transmitter and the program. Al had never heard of this issue...it's almost like the dig is engaged for a moment....if at any point I let off completely or go into reverse it does it again. Sorry I don't have the answer for you...J21 But I will keep an eye on this...I think we're on to something Nice to know I'm not alone |
07-28-2016, 10:08 AM | #13 | |
Theory back in the day was linked to that happening due to what esc gets powered first. If I remember correctly it was power front first then wire off to the rear ..... you get a little rear stall. Are you wired battery to one esc then jumped to the next? | |
07-28-2016, 10:35 AM | #14 |
Rock Crawler Join Date: Feb 2012 Location: OC
Get in there Matt get that shit running!!! . |
07-28-2016, 10:47 AM | #15 |
| Re: Xr10 build few issues It was the other way, rear first, to get rid of (some of) the stall. Didn't really work though.
07-28-2016, 10:50 AM | #16 |
| Re: Xr10 build few issues |
07-28-2016, 06:44 PM | #17 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
If you ordered the motors as a pair, Holmes will have them marked "F" and "R" and they will be running in opposite directions. If you also asked for added timing, then that may be the cause for the difference in forward and rearward speeds. Just a thought. |
07-30-2016, 09:34 AM | #18 |
Mine were "F" and "R" marked....matched pair. I got that part right I'd have to check to see if the battery is wired like that Rob...not sure why that would cause a delay though |
07-31-2016, 02:47 PM | #19 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
08-01-2016, 09:05 AM | #20 |
Xr10 build few issues - Similar Threads | ||||
summit lt build issues | speedysrt4 | Traxxas Crawlers | 4 | 07-23-2014 04:25 AM |
xr10 motors or esc issues | wade toombs | Newbie General | 0 | 12-25-2011 08:19 PM |
XR10 Viper Issues? or am I just fine | Darth Smoke | Axial XR10 | 35 | 03-10-2011 08:24 AM |
issues with rear axle build | slegh | Tamiya TLT Crawlers | 6 | 06-02-2008 08:57 AM |
Need some help - build problems/issues. | Nerve | HPI Wheely King | 25 | 11-15-2007 09:09 PM |
