04-16-2017, 03:03 AM | #1 |
Newbie Join Date: Feb 2017 Location: Australia
| Can you run dual axial ae 2 or ae 5?
Hi, I am starting to build my Axial XR10 and trying to do it on a budget, I plan to get Tekin FXR's and 35t motors down the track but for now, can I run Dual axial AE-2's or AE-5's, with 2 axial 55t motors, of course, I will need a BEC to run these no problem. I also will be running a Spektrum DX4S to run each independent ESC. Thanks Buddy |
04-16-2017, 06:59 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Can you run dual axial ae 2 or ae 5?
Yes, you can run 2 AE-2's, but real estate on an XR10 is very limited. IMO, the preferred ESC's would be a pair of Holmes BR Minis. Much smaller and lighter. Cheaper than FXR's as well. You definitely want to use the BEC for your servo and just power up your receiver with one of the AE-2 ESC's. Remove the red wire from the second. |
04-16-2017, 09:48 PM | #3 |
Sweet makes sense.
04-16-2017, 10:21 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: here
If building on a budget find used castle creation sidewinder micro or sports. But if you can afford Holmes Hobbies br-minis spend your money once. To answer your question yes you can run 2 ae2 or 2 ae5 esc's. Last edited by tapped-out; 04-16-2017 at 10:27 PM. |
04-16-2017, 11:52 PM | #5 |
OK, thanks for the heads up.
04-17-2017, 02:00 AM | #6 |
| Re: Can you run dual axial ae 2 or ae 5? I found this wiring setup, can I use this to wire up my axial AE-2 and 55t Motors, with BEC. |
04-17-2017, 06:02 AM | #7 |
You can but not the way I'd wire it. I'd leave 1 red wire from one esc going into receiver, to power the receiver. Remove the bec from battery port using pos and neg wire connecting them directly to positive and negative on servo leaving only the servo signal wire in Servo port. |
04-17-2017, 06:46 AM | #8 |
Or forget cutting red wires, get the Holmes bypass Hang up and Drive |
04-17-2017, 02:39 PM | #9 |
Ok, but I only thing that my picture doesn't have are capacitors, if I get Tekin FXR and 35t combo, capacitors come with them, what are they for? do I need them? what do they do?
04-17-2017, 03:50 PM | #10 |
Most ESCs come with cap(s) they act as a filter/stabilizer
Can you run dual axial ae 2 or ae 5? - Similar Threads | ||||
SCX10 dual motor and lift kit run. | arctichorse | Scale Videos! | 1 | 01-19-2013 09:48 PM |
What ESC to run with dual motor setup? | Rok Krawl | Electronics | 6 | 06-02-2011 03:53 AM |
Will an XL5 Run Dual Motor? | Twiztid Metal | Electronics | 2 | 11-19-2010 11:53 AM |
Dual ESC to run brushless | Santa Cruz Jeff | Electronics | 1 | 04-03-2010 08:26 PM |
How to Run Dual Traxxas 2075 Servos on SCX10 | alexchen86 | Axial SCX-10 | 3 | 11-24-2009 06:11 PM |
