05-08-2017, 05:12 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| Knuckle weights
How much knuckleweight do you run on your front axle on your XR10? I'm running 76 grams at each knuckle.
05-10-2017, 12:01 PM | #2 |
Rock Stacker Join Date: May 2011 Location: quebec city
| Re: Knuckle weights
Wish knucles weight who use?
05-10-2017, 12:06 PM | #3 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Knuckle weights
I use vp brass knuckles with added rings 149 r/c worx /scalerfab Team Driver |
05-10-2017, 12:21 PM | #4 |
| Re: Knuckle weights
Is the Bras weight for wraith?
05-10-2017, 12:24 PM | #5 |
| Re: Knuckle weights
I run on average about 90grams per side out at the wheel. But weight is more of something thats driver wanted/terrain/vehicle needed type thing. I just mean theres never gonna be a 'you have to run this amount' type number all rigs will run. Where its placed plays in also when you start to think about how much someone is using. |
05-10-2017, 03:08 PM | #6 |
| Re: Knuckle weights
I'm using Rcbros knuckle weight holders. Have also used vp knuckle weights. But can't really decide on What's best, but with Rcbros it is easy to tune the weight. |
05-17-2017, 09:05 PM | #7 |
Newbie Join Date: Jan 2009 Location: Centennial, CO
| Re: Knuckle weights
Any chance with those causing wheel bearing issues?
05-18-2017, 06:32 AM | #8 |
| Re: Knuckle weights Technically anything will hurt the wheel bearings if you add more weight. That little bit of weight wont be a problem, especially compared to the weight and forces the tire/wheel put on the bearing. To answer the original question, yes, its all preference and location. I prefer as much weight as possible. Currently I am running 12.7oz per side of added knuckle weight. |
05-29-2017, 03:31 PM | #9 |
| Re: Knuckle weights
I put the dlux knuckles on my xr10, very impressive stuff , fir the price of slu knuckles and weight add On is very better |
05-29-2017, 04:40 PM | #10 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Knuckle weights Last edited by tapped-out; 05-29-2017 at 04:43 PM. |
Knuckle weights - Similar Threads | ||||
Knuckle weights | Taper | Axial Wraith | 2 | 02-09-2016 01:07 AM |
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
