04-03-2011, 10:19 PM | #1 |
I wanna be Dave Join Date: Oct 2007 Location: 801
| ***Chaotic Crawlers Titanium XR10 links (simple how to)***
Our Titanium link sets will start shipping tomorrow April 4th. This thread is simply to take any questions out of the install. Although installing links is pretty simple, I wanted to give you guys a place to post any questions or use as a reference! ***this link set is designed specifically for the stock axial chassis! it may work with others chassis kits based off the stock axial chassis, but I don't have any for testing purposes*** Now to the fun part!!! The bling... We designed these to work with either a stock rod end or a 4mm traxxas revo or jato rod end (jato would need to be trimmed) For this we will be using the stock axial rod ends for simplicity. First you must drill your rod ends out with a 9/64" drill bit. ( other similar sizes may work, but I found this onre to be the best for strength and thread engagement) You will notice that the XR10 has different rod ends! Our Recommendation/Suggestion of what XR10 Rod Ends to use: All 4 front links use the same rod ends as stock, Front uppers use the short ones Front lowers use the long bent one at the chassis and the long straight one at the axle. The rears is where you have to change it up a little! Instead of using all 4 short rod ends on the uppers, you will instead use... 2 long bent and 2 short bent on both the uppers and lowers! This moves your rear motor up and out of harms way. Once it's all done you should end up with this! View from the front View from the rear If you have any questions please feel free to post them! We are here to help!!! Also I apologize for the dark iPhone pics! I use it for basically everything, and it's very easy for me to just snap the pic and post it. Last edited by Chaotic Crawlers; 07-27-2011 at 12:16 AM. |
04-04-2011, 03:09 AM | #2 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
they look good what do they weigh??
04-04-2011, 04:36 AM | #3 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Been looking for the right links for a little while. I have a FF4 chassis with XR10 axles. So far, I have aluminum links I made out of rod. The Delrin ones I made keep snapping under load. Can you order certain links and not a full set? What are the dimensions from end to end? With my 60/40 chassis, the rear is super long. I am mainly interested in the lower links for now. Wes |
04-04-2011, 05:50 AM | #4 |
Pebble Pounder Join Date: Jul 2008 Location: Grand Island (middle of Nebraska)
Any chance in the future for these link sets to be made for a UGC Viper XR10? I hate guessing on what length works, on front/back uppers and lowers...a straight forward here is what you need to make it work right link set for UGC Viper would be awesome! These look awesome, and after seeing the tie-rod....I love what your doing! |
04-04-2011, 08:33 AM | #5 |
Doesn't the viper use stock xr10 link lengths?? At the moment we are selling them as a lower set, an upper set, or a complete set. I'll get weights later today |
04-04-2011, 09:14 AM | #6 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Vipers do use stock. If you are into making custom ones lkm. I need to figure out how to clear my esc's on my Viper chassis. They are on the battery mount and I want my links inboard like my rear.
04-04-2011, 10:57 AM | #7 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
Great work! those are strait up sexy! not to mention the tech advantages and strength |
04-04-2011, 11:59 AM | #8 |
Thank you bob!!! Hit me up when your ready for a set!!! |
04-04-2011, 12:01 PM | #9 |
I forgot this! Here is your compressed wheel base with these!!! |
04-04-2011, 12:02 PM | #10 |
i think i am goin to get the CF Axial chassis plates this weekend. So i will want these links soon after! You all a CC freggin rule! |
04-04-2011, 09:34 PM | #11 |
| I Weighed the Links tonight. Each Link weighs 9 grams or .3 oz. The entire set of 8 Links only weighed in at 2.6 oz. |
04-04-2011, 09:51 PM | #12 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
Nice work!!! These will be on the must have list for sure |
04-04-2011, 10:30 PM | #13 |
Quarry Creeper Join Date: Aug 2004 Location: salt lake city
Very cool links. nice how to as well.
04-05-2011, 09:46 AM | #14 |
Thanks Deano!!! |
04-05-2011, 04:31 PM | #15 |
| When I used the Axial Stage 3 High-Clearance links, the front was so overly clocked forward that Ive had to cut off 7mm from the top links in the front, and had to ditch the lowers front and rear for CI delrin universals to just get the proper angle front and rear....if you use the stock setup (straight uppers, and the plastic lowers...Im going to guess since they(plastic lowers) were the same length as the aluminium stage 3 ones....you would have the same issues. If someone can show me they are using the chaotic crawlers ti links on a viper chassis, without the over clocking I would gladly buy a set....
04-05-2011, 08:31 PM | #16 |
Rock Stacker Join Date: Jul 2009 Location: pueblo colorado
so what is the cost ? i thank i want a set.
04-05-2011, 08:46 PM | #17 |
04-05-2011, 08:49 PM | #18 |
RCC Addict Join Date: Sep 2006 Location: Depew
| Hmm. I had to shorten my links when I went from stock to Viper so I'd be under 12.5".....
04-05-2011, 09:19 PM | #19 |
I wish I had a viper chassis to test fit them. Have I shown you guys a pic of my granite countertops yet???? Here you go! Pretty nice countertops huh???? |
04-05-2011, 09:30 PM | #20 |
