11-20-2014, 07:30 AM | #1 |
Rock Stacker Join Date: Dec 2012 Location: marion
| has anyone done any shock tuning yet ?
Their a little bouncy out of the box from what I've seen . I just got mine and I'm doing the diffs first so I figured it would be a good time to change shock oil or the shock damper. But have no clue where to start.
11-20-2014, 10:46 AM | #2 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: has anyone done any shock tuning yet ?
I've only moved the springs around front to rear and rear to front, next is thicker oil. This weekend will be more tuning. I'm going to start around 40wt front, maybe 70 rear, and move to the 4-5 hole pistons. |
11-20-2014, 12:28 PM | #3 |
Cool keep us posted on how that works
11-20-2014, 10:35 PM | #4 |
Newbie Join Date: Dec 2013 Location: scappoose
#37.5 wt. rear shock oil. smooths it out
11-21-2014, 10:46 AM | #5 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
I was going to try 35 wt by mixing 40 and 30, just using this calculator for reference R/C Calculations My guess is that anything around that should smooth it out like kcljr said, since 10 wt is far too springy. |
12-05-2014, 06:07 AM | #6 |
Any updates ? I'm doing my shocks this weekend
12-05-2014, 10:25 AM | #7 |
30 wt has been working just fine. I've tested it through the cow pens and cow pastures and it's a lot more smooth feeling than the 10 wt stock oil in the rear.
12-05-2014, 10:56 AM | #8 |
RCC Addict Join Date: Sep 2009 Location: sacramento
did the rears with 40wt and no more twist and way better in the woops |
12-05-2014, 12:33 PM | #9 | |
| Re: has anyone done any shock tuning yet ? Quote:
So I tested this a few weekends ago, I'm not sure if the outside temp had anything to do with it, but it was way too stiff and slow in the rear. I swapped the fluid back to stock 10wt with the 4 hole piston, put the springs back to stock (soft rear, firm front) and it drove great, and jumped really well. Next I'm going to try going back to stock 6 piston and 30-40 wt. I also ordered some springs to cut up and do half springs for a dual rate setup. | |
has anyone done any shock tuning yet ? - Similar Threads | ||||
King Shock Tuning? | Heckler | Axial Wraith | 25 | 02-05-2015 10:40 PM |
Shock tuning ? | JDIRCC | Axial Wraith | 4 | 03-23-2014 11:06 AM |
So much give and take...Shock tuning | 05Fronty4x | Axial Wraith | 3 | 05-16-2013 04:10 PM |
Shock Tuning | BCSteel | Newbie General | 0 | 02-16-2013 08:25 AM |
Team Zero Shock Tuning | TrailDawg362 | Axial AX-10 Scorpion | 0 | 10-12-2010 02:06 PM |
