11-25-2014, 04:58 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Chandler
| Turnigy 3S Packs dont fit in the battery compartment!!!
Just a warning before you guys go out and buy Turnigy Packs for this Truck!! Bought 2 Turnigy Nano Tech 3S 6000mah Lipos and they are about 7.8mm too big for the battery compartments. The packs are 48mm wide and the door wont close even if I try and force it I cant return the packs so now im going to have to jimmy rig something to keep these packs secure. Maybe a velcro strap or figuring out a way to extend the door a bit but this is no bueno Or I guess I could try sell the packs and buy ones that actually fit. What 3S Lipos are you guys running with no issues? |
11-25-2014, 05:31 PM | #2 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
| Re: Turnigy 3S Packs dont fit in the battery compartment!!!
Traxxas 3s 5000's fit really good.
11-25-2014, 08:40 PM | #3 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
Just curious. How tall are those packs?
11-25-2014, 08:54 PM | #4 |
Newbie Join Date: Jun 2014 Location: Australia
I have Turnigy 2S 6.0 packs and they only just fit... (my packs are 46.25mm wide. Length and height are fine) Last edited by o0ben0o; 11-25-2014 at 10:30 PM. Reason: adding pack dimensions |
11-25-2014, 10:10 PM | #5 |
Pebble Pounder Join Date: Nov 2011 Location: raceland
I sure hope my bias 3s packs and my sky lipo 2s packs will fit. Have you tried velcro the industrial strength stuff is pretty good. Also you maybe able to drill a small hole thru the plastic thats supposed to accept the clip. Run a long but small bolt thru there and just use a nylon nut to hold it tight. Just ideas. Good luck. |
11-25-2014, 10:44 PM | #6 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
A buddy of mine zip ties the door shut on certain packs her runs. I think all Axial needs to do is release a wider door as a adjustable battery compartment.
11-25-2014, 11:38 PM | #7 |
The Trax 3s 5000 is only 42mm wide x 25mm thick Right now i'm using the new hard case 80c 6400 Reaction Dynamite packs,awesome power for 2s packs.They are 45mm x 24mm and i would say that 45mm wide is about max width to close the door. |
11-26-2014, 06:31 AM | #8 |
Pebble Pounder Join Date: Sep 2009 Location: Rockport, TX
Might try some of these (the metal post only) screwed to the cover (would have to shave off the original posts)? http://www.rceasy.com/2007/11/03/traxxas-battery-expansion-kit/ |
11-26-2014, 07:20 AM | #9 |
Newbie Join Date: Nov 2014 Location: Santiago, Chile
Running 3S, 5000mah, 45-90C, 138x42x30mm for hard bashing in open places, made by my local hobby shop in Chile, and 2S SMC factory spec 9400mah, 60-120C, 162x47x29.2mm for long endurance bashing and trails, great duration for the $$
11-26-2014, 03:08 PM | #10 | |
Thanks for that, it will definitely solve my problem and allow me to keep my 6000mah packs. Quote:
11-26-2014, 04:02 PM | #11 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
For a quick fix, I would dremel a slot for a velcro strap through the tray door and then just dremel a slot out in the tray itself to slide it through, then just velcro the doors shut in cases like that.
Turnigy 3S Packs dont fit in the battery compartment!!! - Similar Threads | ||||
Fixing a broken transmitter battery compartment | sixty2 | Electronics | 0 | 10-08-2014 11:44 AM |
turnigy 2200 packs in add on forum....... | bob1961 | Electronics | 7 | 05-03-2012 04:04 AM |
