Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Battery Door mod for wider packs!!
Old 11-28-2014, 10:49 PM   #1
Default Battery Door mod for wider packs!!
Thanks to mfishr for this idea
I didnt want to give up my brand new 6000mah Turnigy 3S Packs so with a little Traxxas Battery post I was able to give myself the extra 5mm i needed for the wider packs. Battery is secure and no issues of clearance when the body is down!!
djmaincheese is offline   Reply With Quote
Old 11-30-2014, 07:29 PM   #2
Default Re: Battery Door mod for wider packs!!
What is the part number? Great idea, same problem here!
fatroofus is offline   Reply With Quote
Old 11-30-2014, 09:15 PM   #3
Very nice. I'm going to have to try this. Might be cool to incorporate a spring too. That way it could hold packs secure even if between 2 pin holes
coryshad is offline   Reply With Quote
Old 11-30-2014, 10:02 PM   #4
Nice idea.
SteveC6R is offline   Reply With Quote
Old 12-13-2014, 04:23 PM   #5
Sweet!
I believe these are what was used....
http://www.ebay.com/itm/Traxxas-Batt...item35d6e5eb5e
ednerin is offline   Reply With Quote
Old 12-22-2014, 12:36 PM   #6
I have the parts now, and about to go do this to mine... But what prevents the pins from sliding out when I remove the clips?
I see you added a nut on one side, but what about the other side of it?
Thanks,
Aaron
Battery Door mod for wider packs!! - Similar Threads
Wheel mod to make a wider wheel. 808DA6 Micro Scale Rigs 5 05-22-2014 10:24 AM
How much wider is the XR mod ? OfnaJoe Axial SCX-10 8 08-01-2013 01:45 PM
Wider axle mod??? Tgreer Team Losi Comp Crawler 25 11-30-2012 07:50 PM
Another way to mod a rim for wider stance DANALLY Losi Micro-Rock Crawler 10 11-01-2011 02:34 PM
