12-20-2014, 08:57 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: Canada, Quebec, Montreal
| quick release body mount
i like the body and i like that it swings up for acces, but when working on the truck it pisses me off... i get tired of removing the 2 long screws in the rear. i am wondering if anyone has come up with an idea for a quick removal of the body ? thanks, Anthony |
12-20-2014, 08:59 PM | #2 |
I joined the Band! Join Date: Dec 2007 Location: Philippines
| Re: quick release body mount
2 long screws? I remove 2 screws that have about 4-5 turns to each that are like 1/4 inch long.
12-20-2014, 09:33 PM | #3 |
? i remove the 2 long ones that are on each sides, where it pivots. |
12-21-2014, 06:45 AM | #4 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
Two short screws on the bottom of the mounts is all I remove, 5 seconds tops to get the body off.
12-21-2014, 11:20 PM | #5 |
Quarry Creeper Join Date: Sep 2011 Location: NW
i have found the transmitter can stand up on the rear of the motor and hold the body(hood) open. I've done slot of work and have yet pulled the body off.
12-22-2014, 03:50 PM | #6 |
thanks steve and rusten, i'll try that until i figure a way of removing/installing it in seconds without tools.
12-23-2014, 09:30 PM | #7 |
i did try the 2 screws from the rear, and its a bad angle, feels like it will strip the screws head. also have to force/bend the mount to get it over the ''pivot'' im still trying to find a quick release mount with body clips. |
12-23-2014, 09:34 PM | #8 |
Newbie Join Date: Nov 2014 Location: Mountain View
I find the same issue but you can stand the body pretty much vertical by unloading the rear suspension and when you let go the body will stand straight up. I am not sure if you need more access than that. The two screws are in a weird angle. |
12-23-2014, 09:56 PM | #9 |
Pebble Pounder Join Date: Nov 2014 Location: philadelphia
You can replace the head screw on the rear axle with a longer screw and spacers so that when the body is in the locked position with suspension unloaded it can't get knocked out of place which it currently always does. Check out this thread, 2nd post, to better describe with pictures. Axial Yeti XL Tips N' Tricks - R/C Tech Forums |
12-24-2014, 10:16 AM | #10 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
I just use a small velcro strap that I just wrap around the very end of the body cage and strap it to the rear axle, it doesn't budge and doesn't take any time.
quick release body mount - Similar Threads | ||||
ANOTHER new proline bug body release... | STANG KILLA SS | Paint and Body | 12 | 11-23-2010 03:27 PM |
Cheap and quick antenna mount | dont slow down | Tools, and Procedures | 12 | 11-14-2008 12:44 PM |
Axia Rod Rat body - October release | rcpaintworks | Paint and Body | 21 | 11-07-2007 09:44 PM |
