12-21-2014, 07:38 PM | #1 |
Newbie Join Date: Sep 2007 Location: Hillsboro
| Bent spur
Ran the yeti today... Managed to bend/warp the spur gear. Pinion set screw came lose too. No idea how this happened.
12-21-2014, 08:10 PM | #2 |
Rock Stacker Join Date: Mar 2011 Location: Canada, Quebec, Montreal
| Re: Bent spur
you sure its not the trans shaft that is bent?
12-21-2014, 08:31 PM | #3 |
12-21-2014, 09:49 PM | #4 |
Quarry Creeper Join Date: Sep 2006 Location: nor cal
| Re: Bent spur
mine did the same I thought.. it was the plastic spacer in the center of the gear. replace it with a bearing. prob all fixed.. that spacer gets hot and out of round..
12-22-2014, 06:48 PM | #5 |
Pebble Pounder Join Date: Nov 2010 Location: Charlotte
| Re: Bent spur
what size bearing
12-22-2014, 07:18 PM | #6 |
| Re: Bent spur
the same size as the plastic bushing you took out..
12-22-2014, 08:04 PM | #7 |
Pebble Pounder Join Date: Apr 2008 Location: Mtn Home ID
| Re: Bent spur
5 x 11 x 4 mm Ball Bearing
Bent spur - Similar Threads | ||||
Bent links or not bent likes that is the question? | Ktbone | Newbie General | 67 | 01-06-2012 05:10 AM |
How Bent is Bent? (Trans Input shaft) | Grouper | Axial AX-10 Scorpion | 7 | 01-06-2012 01:32 AM |
Be careful with your Losi bent links / DIY bent links as a result | Russ | Losi Mini-Rock Crawler | 14 | 01-06-2009 04:43 PM |
