01-17-2015, 09:12 AM | #1 |
Rock Stacker Join Date: Jan 2015 Location: jal
| No 4wd
So I was out bashing this morning and after 20 minutes or so I noticed 4wd is gone and the front wheels are not spinning. Brought the truck inside pulled the body off and dumped it upside down to see if anything falls out and AX31045 screw shaft m4x2.5x13mm fell out *would post picture but don't know how lol* is that part connecting to the drive shaft or diff? Figured I stripped the diff gears but before I got that far into tearing it apart thought id ask! Its a little smaller than the size of a dime if that helps. Last edited by exokiler; 01-17-2015 at 09:15 AM. |
01-17-2015, 09:20 AM | #2 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: No 4wd
Nope, it goes on the front drive line output on the tranny. All your other parts should still be there, just put the pin back in with a little blue loctite and you should be good to go.
01-17-2015, 09:22 AM | #3 |
| Re: No 4wd
Ok cool I will figure out the best way to get it back in later today. Im going to pick up a hex set and Loctite so it don't happen again.
01-17-2015, 09:53 AM | #4 |
RCC Addict Join Date: Jun 2012 Location: Meridian,Id
| Re: No 4wd
had that happen on my yeti jr.
No 4wd - Similar Threads | ||||
rc 4wd | dman10 | Losi Mini-Rock Crawler | 13 | 06-18-2011 04:12 PM |
4wd? | orangecc | Duratrax Cliff Climber | 8 | 07-09-2009 07:12 PM |
Dig ?, 4wd-fwd-brake Or 4wd-fwd Only ? | twisted | General Crawlers | 2 | 01-12-2008 02:26 PM |
