Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: What else should I order with the YXL kit
Old 03-09-2015, 11:09 PM   #1
Default What else should I order with the YXL kit
So after a few years ( Last RC purchase was Savage SS kit ) I am gonna hop back into things and get Yeti XL. I am pretty sure my old Novak T-4 won't cut it so I have a long list of things I need to get. I ordered a RadioLink RC3S with hi voltage receivers to replace my Ko Propo EX-11 . I won't bother asking about motor/ESC because there is plenty of info on here for that. Savox SA1230SG servo will be getting ordered soon. My question is when I place my order with Tower for the kit, what else will I need. I have all my old tools and allen drivers but as far as all the little extra stuff, Im going to assume that I don't have it. Any input will be appreciated
Things I NEED :
Tire glue
olfajarley is offline   Reply With Quote
Old 03-10-2015, 10:08 AM   #2
Default Re: What else should I order with the YXL kit
My kit is being delivered today!
I have a savox sc1230mg as well set aside for mine, but this servo is a little taller than standard and will require some spacers between the servo and chassis to fit. There is a thread about this on this form
I would also recommend a fast eddy bearing kit. The RTR bearings are not holding up well and causing issues in the drivetrain. Fast Eddy bearings are higer quality and will be much easier to install while building the kit.
Also I have a dhawk Aluminum steering bellcrank and plate to help with steering and durability.
Lastly I would recommend steel pivot balls 3x6.8x8x8mm. the kit and RTR version have plastic pivot balls which wear out quick and create a lot of slop. These pivot balls are available on ebay in quanitity of eight. I ordered three sets so I can use them on the shocks, steering turnbuckles, and rear suspension links.
BobTeagle is offline   Reply With Quote
Old 03-10-2015, 10:17 AM   #3
These parts probably aren't needed but I also ordered the following:
aluminum shock tower
aluminum body post mount
aluminum front brace
Aluminum skid plate
aluminum motor mount
Aluminum spur gear cover
Aluminum upper shock mounts
Aluminum upper link mounts
Aluminum lower link mounts
Aluminum steering posts
I got all of this in titanium color to match the lower link braces included in the kit.
Old 03-10-2015, 10:50 AM   #4
Aluminum skid plate
Where from?
jwolfe4 is offline   Reply With Quote
Old 03-10-2015, 11:15 AM   #5
Tire glue. Youll need a lot as there are five, and they are huge.
Angus_Beef is offline   Reply With Quote
Old 03-10-2015, 01:20 PM   #6
Jwolf4,
I got all the aluminum bits off ebay. Dhawk and GPM parts
Old 03-10-2015, 05:43 PM   #7
A Savage XL. My YXL had to be shipped to hobby services for repair after only 5 runs,
ednerin is offline   Reply With Quote
Old 03-10-2015, 07:40 PM   #8
What broke on it?
Old 03-10-2015, 07:55 PM   #9
Front diff outside bearing went taking out the front diff the rear diff also lost some teeth the trans had issues on the shafts where the pin holds the gears were elongating and not allowing the bearings to be removed. So when I called for replacement parts they requested I send it to them for repair. They got it yesterday we'll see how long it takes to come back. Its only been run five time but of course the last time was 6s. I do not recommend running this RC on 6S as I don't think it was designed for that amount of power. Nothing but problems every time I run it we'll see what happens. I do highly suggest anyone upgrade the bearings on this RC. Just my humble $.02.
Old 03-10-2015, 08:32 PM   #10
Well that fixes that. I just ordered the Fast Eddy bearings
Old 03-13-2015, 07:10 AM   #11
Can I ask what tire foams are recommended for the stock Yeti XL kit tires?
skeeler is offline   Reply With Quote
Old 03-13-2015, 09:50 AM   #12
I don't know what foam is recommended but I will be adding a 2" strip of gorilla tape on the inside to help with ballooning issues a little
Old 03-13-2015, 09:53 AM   #13
Crawler Innovations sells single stage closed cell foams for the XL
crockins is offline   Reply With Quote
Old 03-13-2015, 10:30 AM   #14
Thanks.
Old 03-14-2015, 03:34 PM   #15
Since this thread is about what you should order with Yeti XL kit, it seems like a good place to ask what the recommended durability mods are. Can anyone offer guidance on that topic?
Old 11-06-2016, 05:32 PM   #16
Who makes these alum parts you speak of and where did you get them?
chs51 is offline   Reply With Quote
Old 11-06-2016, 07:54 PM   #17
Hot Racing, DHAWK and GPM make most of all the AL upgrade stuff. All found on ebay.
pro mod steve is offline   Reply With Quote
Old 12-03-2016, 06:01 AM   #18
Are these the recommended foams --> LINK
Thank you
Axial Rose is offline   Reply With Quote
Old 12-03-2016, 05:09 PM   #19
Yes.
What else should I order with the YXL kit - Similar Threads
Wheels for the YXL Duramarks Axial Yeti XL 19 03-21-2015 11:25 AM
Preordering my kit - what else should I order with it? Rudukai13 Axial Yeti 31 08-26-2014 07:30 AM
fixin to order kit any suggestions tacklebox421 Axial Wraith 10 04-20-2012 09:12 PM
D110 kit order help flomofo 1.9 Scale Rigs 2 04-08-2012 04:29 PM
Getting TLT kit with money order? trickedoutTLT06 Newbie General 1 11-02-2006 06:14 PM
