04-11-2015, 08:24 PM | #1 |
Rock Stacker Join Date: Apr 2015 Location: Augusta
| Servo Install
First post. Building my kit now. My Hitec servo must have the wire folded under and fed out the back. My question is the "spacers" In the kit are two plastic pieces that look like servo spacers. Is that what they are? I installed one under my servo to raise it up a few mm (servo sits on top of it and bolts through it) to allow clearance for the wire. Would it be better to just pinch the wire? I had to add a washer to the steering link to drop it down a hair to clear.
04-11-2015, 09:38 PM | #2 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Servo Install
My Hite fit just fine with the wire under it. Have another look.
04-12-2015, 07:00 AM | #3 |
| Re: Servo Install
It fits I was not sure if it was a good idea crushing the wire under it, so I spaced it up but with the steering already a little sloppy not sure if spacing the servo a little higher is a good idea either.
Servo Install - Similar Threads | ||||
Servo Install ??? | wraithmike | Electronics | 2 | 03-01-2014 11:24 AM |
AX10 new servo install | CAS | Axial SCX-10 | 3 | 03-31-2012 05:06 PM |
Servo install ? | Colbygib04 | Axial Wraith | 0 | 01-12-2012 07:12 PM |
Servo Crown(TM) Servo Armor(TM) install | PinchFlat | Chassis and Suspension | 8 | 06-06-2008 11:08 AM |
servo install | jmizoguchi | Axial AX-10 Scorpion | 11 | 09-12-2007 10:21 AM |
