04-20-2015, 01:25 PM | #1 |
Newbie Join Date: Mar 2015 Location: US
| kit tires - what glue to use?
I know this may sound foolish, but I've tried two types of things CA followed by medium CA and I keep blowing the tire off the rim within a few minutes. I've reglued each tire several times now, I've installed the glue deep into the seam for max grip but it just doesn't want to stick...wth. Any advise would be appreciated as the truck is running great other than the tire failures. Maybe I need to buy a new set and start over with the correct CA? (Not sure what that would be at this point) |
04-20-2015, 01:32 PM | #2 |
| Re: kit tires - what glue to use?
The YXL is the first time i glued tire in a lot of years. Cleaned the tires and used this Muchmore Racing Instant Rubber Tire CA Glue (20g) [MMRCHCAR] | Maintenance - AMain.com - AMain.com I only have 1 or 2 spots coming off the lip of the rim that are mm in size that are showing up. Most likely due to my glue job. Unless you can start over you are going to have to band aid it with better glue.
04-20-2015, 03:08 PM | #3 |
| Re: kit tires - what glue to use? http://pages.ebay.com/link/?nav=item...354997&alt=web Thanks. I didn't realize that special glue was needed so I'm going to run what I have until they fail again and then spent the time with debonder and cleaning alcohol so I can start over with this new glue. Good lesson learned that regular thin and medium CA doesn't work very well with tires. |
04-20-2015, 03:11 PM | #4 |
Rock Crawler Join Date: Jul 2009 Location: roseburg
aka i use
04-20-2015, 03:30 PM | #5 |
| Re: kit tires - what glue to use? I've used thin and medium and thick over many years and found they all work fine. Pretty sure a very lot of people have. And there's no need to pay for brand names, it's all the same cheap CA glue you get everywhere with a different name on it. There's only a few chemicals that make up a CA glue. Cyanoacrylate is cyanoacrylate. Drying agents make up the majority of the differences.
04-20-2015, 05:08 PM | #6 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Dont bother gluing them - you'll be at it all day and you wont be happy with the results - get some beadlocks. Now I wish there were some available.....
04-21-2015, 07:24 PM | #7 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
Those tires were a tad difficult, but I found the yellow tips Proline gives you really helped getting the glue were I wanted it. Plus I could add glue under the bead in large sections, about a 1/4 to 1/3 of the tire at a time. After they dried, anywhere I missed, I could easily add glue without any mess. |
kit tires - what glue to use? - Similar Threads | ||||
What do you guys use to glue tires other than CA glue? | country_crawler | Tires and Wheels | 38 | 03-17-2015 11:10 PM |
To glue or not to glue...rear tires | Snipervision | Losi Mini-Rock Crawler | 3 | 12-24-2010 11:01 AM |
Re-glue Tires | fiveo | Losi Micro-Rock Crawler | 5 | 04-27-2010 06:05 AM |
CA Glue for tires | Savrunner | Newbie General | 7 | 02-01-2007 10:38 AM |
