04-25-2015, 09:13 PM | #1 |
Newbie Join Date: Apr 2015 Location: Amarillo
| turning sharper one way than other
My mind is boggled right meow. Servo horn is on correctly , I even fiddled with the end point adjusment on my radio and it's still turning sharper to the left than the right. Any tips?? |
04-25-2015, 09:20 PM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: Vancouver Island, BC, Canada
| Re: turning sharper one way than other
try setting your toe with your tie rod?
04-25-2015, 09:21 PM | #3 |
Pebble Pounder Join Date: Mar 2015
Lean harder to the right? ? I had a similar issue. Turned out my servo horn was a bit to long, and it was hitting something in one direction. I put on a shorter horn, and that resolved it for me. You can disconnect the link from the horn to check if the rest of the steering linkage is working ok.
04-25-2015, 11:39 PM | #4 |
It works fine when the horn is off. I can move it by hand lock to lock. And if I adjust the tierods it just throws everything off. It's odd though the aluminum horn I have isn't any bigger than the Plastic one that came in the kit
04-25-2015, 11:54 PM | #5 |
Check the height of the turnbuckle. The rod end may be rubbing the large bulkhead brace it goes under. I've seen reports of folks needing to find servo horns that didn't sit so high when mounted on the servo to avoid this.
04-26-2015, 01:06 PM | #6 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
"I'm sorry, did you just say 'Meow'?" If it is working correctly with the servo horn off, you need to check for binding somewhere. |
04-26-2015, 01:12 PM | #7 |
turning sharper one way than other - Similar Threads | ||||
Sharper turning? | hijack | 1.9 Scale Rigs | 7 | 05-18-2013 11:20 AM |
Turn sharper? | InFlames | Duratrax Cliff Climber | 7 | 04-07-2009 06:33 AM |
How to get a AX 10 to turn sharper? | jeffc | Axial AX-10 Scorpion | 9 | 02-08-2009 01:06 PM |
Sharper steering | 1tuff40 | Axial AX-10 Scorpion | 16 | 09-27-2008 07:28 PM |
Sharper clod turning | CrawlinJunky | Tamiya Clod Buster | 10 | 04-30-2008 06:31 PM |
