05-03-2015, 07:32 PM | #1 |
Newbie Join Date: Feb 2015 Location: Salisbury, NC
| Low voltage cutoff not working
My low voltage cutoff is not working? I have external bec installed with red wire removed on esc plug. Anybody got any suggestions as to why my lvc isnt working?
05-03-2015, 09:02 PM | #2 |
Rock Crawler Join Date: Dec 2014 Location: Rhode Island
| Re: Low voltage cutoff not working
How low did your lipos go? The LVC cuts out at 3.4v stock I think so when your lipos hit 20.4v it will sputter and cut out. Hard cut is a little lower voltage. If you have one or two low cells and your still over 20.4volts total then the LVC will not kick in. The red power wire has nothing to do with it. The ESC reads the battery volts from the batteries themselves. |
05-04-2015, 05:42 AM | #3 | |
| Re: Low voltage cutoff not working Quote:
05-04-2015, 12:14 PM | #4 |
Are you running the same batteries? The Low voltage cutoff cannot see the individual voltage of each cell in the lipos, it only sees a total voltage and will cut off when it hits that value. If you have it set for 3.5 and running 6S the LVC will hit at a total of 21 volts. |
05-04-2015, 01:00 PM | #5 |
| Re: Low voltage cutoff not working Because your cells are not matched. The LVC will cut out at a total voltage. It can not see the voltage of each cell. You could have a cell at 2.5v and the rest at 3.6 and your LVC would still not cut out the power.
05-04-2015, 01:43 PM | #6 |
Yes im running the same batteries helios rc. I had one battery around 2.9v on all three cells and the other around 3.5v on all three cells. If you do that math the lvc didnt start cutting out till 19v. It is set at 3.5v
05-05-2015, 03:32 AM | #7 |
Reset the ESC settings and put the LVC at 3.6v and see what happens. That is weird though. Why would one Lipo discharge more than the other. Being in series it's the same load on both batteries. Its like you have three week cells on one and three stronger cells on the other. That would mean the batteries are made with different cells in them. Almost like running a 30c Zippy and a 50c Venom in series. You'd end up with different voltages that way.
05-05-2015, 07:04 AM | #8 |
Pebble Pounder Join Date: Mar 2015
If you wired your BEC to one battery instead of both, then the battery with the BEC will see more power draw, but the LVC will only respond to the total voltage the ESC sees. Also, make sure you are balance charging.
Low voltage cutoff not working - Similar Threads | ||||
Stock low voltage cutoff settings | P-J | Axial Yeti | 6 | 02-05-2015 10:28 PM |
Low voltage cutoff? | Tgreer | Electronics | 10 | 05-28-2012 03:53 PM |
low voltage cutoff and bec | aircooled67 | Electronics | 6 | 12-20-2009 11:26 AM |
external low voltage cutoff | some_guy | Electronics | 3 | 01-09-2008 04:44 PM |
Low voltage cutoff????? | bastard | Electronics | 7 | 11-25-2006 04:48 PM |
