Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: 17mm hub nut replacement (the nut that holds the wheel on)
Old 08-01-2015, 04:04 PM   #1
Default 17mm hub nut replacement (the nut that holds the wheel on)
Is this the only option for replacing a lost hex nut for the kit version YXL?
TowerHobbies.com | Axial Hex Hub Set 17mm Yeti XL (2)
Can anyone confirm if these will work?
TowerHobbies.com | ARRMA Wheel Nut Aluminum 17mm Black (4)
TowerHobbies.com | Hot Bodies Wheel Nut 17mm Black (4)
TowerHobbies.com | HPI Racing Heavy Duty Wheel Nut 17mm M12 Black (4)
TowerHobbies.com | Traxxas Wheel Nuts Splined 17mm Green (4)
olfajarley is offline   Reply With Quote
Old 08-01-2015, 05:12 PM   #2
k7zpj's Avatar
Default Re: 17mm hub nut replacement (the nut that holds the wheel on)
There a multiple threads on this.
I went with the Nyloc to help prevent it coming off again.
TowerHobbies.com | Associated Nyloc Wheel Nuts Black (4)
Any of the 17 mm wheel nuts you listed should work.
k7zpj is offline   Reply With Quote
Old 08-01-2015, 05:14 PM   #3
Awesome thank you
Old 09-06-2015, 08:54 AM   #4
Well lost a hex first outing with new axles and hex kit. I had some traxxas Hex nuts and this are wrong thread pitch will only go on one or two threads. Would like to drive my toy!!!!
themacguru1 is offline   Reply With Quote
Old 09-07-2015, 09:16 PM   #5
Got some nyloc's today
Associated PN# 89405
Old 09-11-2015, 10:07 PM   #6
I have ran these King Headz Flanged Wheel Nut for a while on my RC8Te and they have been problem free. They are a flanged nut which should add some extra support. They use dots vers a serrated edge. I have not had one come loose yet. But I have been lucky with the stock ones so far. I do check mine after each use with a good wrench.
MaxxPain is offline   Reply With Quote
Old 09-12-2015, 06:32 AM   #7
Liking those flanged nuts. Did you use the coarse or fine thread nuts?
Lozza is offline   Reply With Quote
Old 09-12-2015, 08:25 AM   #8
Those look very nice. I have found blue loctite to be very effective for me.
Sent from my SM-N900V using Tapatalk
Motorider is offline   Reply With Quote
Old 09-12-2015, 11:38 AM   #9
Fine thread.
Old 10-20-2015, 12:53 PM   #10
This past weekend, I had my flanged nuts come loose. This was the 2nd time it happened. So, I cant say this is a fix for loose nuts. They do support the wheel very well, but I would recommend either a socket wrench when tightening and or center punch the holes a bit deeper to cause a better bight. I think with the wheel being so soft, its tuff for the nut to dig in and stay.
17mm hub nut replacement (the nut that holds the wheel on) - Similar Threads
TCS 17mm Nut For Savage kevinlongisland Vendors Market 0 09-13-2013 12:22 PM
~The Scale Shop~ Locking Hub Wheel Nut Covers! STANG KILLA SS Vendors Tires and wheels 22 01-11-2009 12:45 AM
