Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Rear shock damper by gpm
Old 08-12-2015, 11:22 AM   #1
Default Rear shock damper by gpm
How does the rear shock damper by gpm install? Any try this yet any pics?
gregm412 is offline   Reply With Quote
Old 08-12-2015, 12:08 PM   #2
Default Re: Rear shock damper by gpm
it looks to me like it clamps around the plastic tubing on the body and strengthens the plastic joint. it looks well made, maybe a little bit of overkill.
Motorider is offline   Reply With Quote
Old 08-12-2015, 08:37 PM   #3
You will break the shock caps first. I have already done it and the upper mount is still perfect.
pro mod steve is offline   Reply With Quote
Old 08-13-2015, 07:51 AM   #4
It goes on the back of the frame. The benefit is putting load onto more screws and onto metal rather than onto plastic. It's a worth while upgrade for long term durability. I'd also upgrade the shock caps. Plastic shock caps was a mistake on this kit.
mond is offline   Reply With Quote
Old 08-27-2015, 08:49 AM   #5
I installed mine yesterday it installs on outside of frame where stock location is. It moves shocks back and below.
Kind of a pain to install shocks when installed. I bolted shock on new piece then installed on frame.
themacguru1 is offline   Reply With Quote
Rear shock damper by gpm - Similar Threads
GPM rear diff gears vinnyphx Tamiya XC/CC01 1 07-01-2014 08:09 AM
Damper/Shock queastion? bretkissick General Crawlers 3 02-26-2012 02:45 PM
Rear Shock Mounts TruckerBrad Tamiya XC/CC01 13 01-21-2010 12:01 AM
My 1 Shock Rear Setup MudBoGGinMaxX General Crawlers 2 02-07-2006 06:51 PM
