09-04-2015, 01:34 PM | #1 |
Newbie Join Date: Dec 2009 Location: ANDOVER TOWNSHIP
| How much voltage
Does any one know if the Futaba R603FF receiver and the Hitec HS-7955TG servo handle more than 6.0 volts?? |
09-04-2015, 01:45 PM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
| Re: How much voltage
The Receiver should be able to handle 7.2V. Output however will be 6V. Why would you "overpower" the servo?
09-04-2015, 04:08 PM | #3 |
More voltage more power?? Third channel supporting motor fan/many LEDs!
09-06-2015, 03:50 PM | #4 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
7955tg can run 7.4v. Look it up, lots of info and hitec confirming it as well.
09-07-2015, 08:33 PM | #5 |
Also, when you get into servos that have 7.4v ratings, it's cause most of them can run off 2s lipo's.. Which means they can handle 8.2-8.4v.. Disclaimer: just cause I run my 7950's, 7980's, and HH servo's on 8.2v-8.4v doesn't mean you have to! But it can be done and works fine.. ;) |
How much voltage - Similar Threads | ||||
Rx voltage | TheSaundo | Electronics | 3 | 04-19-2011 05:43 PM |
NEED INFO: High kV + Low Voltage 'vs' Low kV + High Voltage? | Chadworkz | Electronics | 9 | 01-28-2009 06:56 PM |
more voltage? | spinner | Electronics | 3 | 12-16-2008 05:01 PM |
What voltage? | RIVERdude69 | General Crawlers | 6 | 02-09-2006 08:48 AM |
