03-23-2016, 04:20 PM | #1 |
Newbie Join Date: Mar 2016 Location: Hustisford, WI
| Axial Yeti XL and Hot Racing Bulkhead
I ordered a Hot Racing front aluminum bulkhead for my Yeti XL and it arrived today. After reading several posts I was a bit concerned about the bearing fit, but I was pleasantly surprised... Even made a quick video to share. https://youtu.be/CAd4ilHdG0g Last edited by SeanKewley; 03-23-2016 at 04:22 PM. |
03-23-2016, 08:17 PM | #2 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Re: Axial Yeti XL and Hot Racing Bulkhead
Thanks for the vid. WAY better than the hammer video.
03-26-2016, 03:32 PM | #3 |
For those of you who have used the Hot Racing front Aluminum bulkhead or the Dhawk version... Has this helped to reduce blown diff bearings? My thoughts were that the plastic bulkhead was allowing flex to occur and damaging the bearings in the process. Any merit to this? I caught the failed bearing before it damaged my crown and pinion diff gears (Non-HD gears) and was hoping the aluminum bulkhead would help mitigate this. Thanks, |
03-26-2016, 09:35 PM | #4 |
Pebble Pounder Join Date: May 2015 Location: Baton Rouge
It absolutely helps... especially when combining with upgraded diff bearings.
03-27-2016, 10:49 AM | #5 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
Did you put HD gears in it? I may order the HR. I like the way it goes together better than the Dhawk.
03-27-2016, 11:03 AM | #6 |
Rock Stacker Join Date: Dec 2015 Location: Canada
| Re: Axial Yeti XL and Hot Racing Bulkhead |
03-27-2016, 12:15 PM | #7 | |
| Re: Axial Yeti XL and Hot Racing Bulkhead Quote:
Sparwood, I got mine from here: Hobby Etc 603-883-4919 26 Clinton Dr. Unit 119 - Hollis, NH USA Only took 2 days for delivery. | |
03-27-2016, 12:36 PM | #8 | |
03-27-2016, 01:03 PM | #9 |
One other modification I forgot to mention when installing the HR bulkhead. You need to trim a small amount of the plastic channel on the bottom of the plate that mounts to the top of the bulkhead. Presumably this mod is only needed if you use the OEM top plate instead of buying HR's. |
03-27-2016, 04:36 PM | #10 |
Pebble Pounder Join Date: Sep 2015 Location: Wa st. Olympic peninsula
Either you got lucky or they had some complaints and made some changes, hopeful they made the changes and it is not a hit and miss issue, mine is still a tight fit even after removing material from inside. I purchased the DHawk bulk with out issues.
03-28-2016, 10:55 PM | #11 |
Well, OK, just pulled the trigger on one, I'll let you know how I make out when it gets here.
03-29-2016, 03:19 AM | #12 | |
Pebble Pounder Join Date: Nov 2013 Location: Southeast MI
Very interested in this thread. Keep us in the loop. Just blew my front diff (I think) over the weekend. Haven't pulled it apart yet. I want to get a good parts list together so this doesn't happen again (bulkhead, HD ring/pinion, bearings?, etc.) I was thinking hot racing this time, now not so sure. Thx | |
03-29-2016, 10:18 AM | #13 |
I have 1.5 hours of running so far on the HR Bulkhead and new bearing. No bearing issues so far. I plan to disassemble the front diff when I hit 5 hours to inspect the bearings and gears.
03-30-2016, 12:28 AM | #14 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
I had to change my Acer bearings after less than 5 hours. Lucky me, they was almost gone when I did the inspection. But only the outer ones, the inside ones next to the pinion were kind of ok. Changed them anyway, Losi in the rear and Mugen on the front, or vice versa, don't remember now exactly which is where Last edited by Tzicul; 03-30-2016 at 12:58 AM. |
04-07-2016, 12:33 AM | #15 |
Anyone running the HR bulk with the Dhawk steering link. I am trying to get mine together and it looks like I'd have to trim a lot of the material from the link to get it to fit. It interferes so bad with the HR bulk I can't even get it together.
04-07-2016, 07:36 AM | #16 |
Newbie Join Date: Jan 2016 Location: midwest
Yes I did try that combination. Don't think you can remove enough material from the link to clear the bulkhead. Went with the Hr steering bellcrank because the link sets lower. Hr unit is not nearly as nice as the Dhawk unit.
04-07-2016, 07:58 AM | #17 |
| Crap, that stinks, do you know if the stock steering setup fits. At least I can get it back running well I'm waiting.
04-07-2016, 10:18 AM | #18 |
I have the dhawk steering bell crank and the HR bulkhead. I filed a little off the bulk head and bell crank link and have no clearance issues now. NOTE. You should attach the front to the chassis each time you file as it will rub no matter how much you file until the front is fully attached and screwed to chassis. The final assembly will change the angle of the bell crank to bulkhead and you will not get the proper alignment/angle until that is done
04-07-2016, 11:54 AM | #19 | |
04-21-2016, 07:21 PM | #20 |
I just checked the bearings in the front and rear differential after replacing the OEM bearings with Fast Eddy bearings and the Hot racing front bulkhead, and I am happy to report that after 5 hours of hard running on 4S, all bearings are still in good shape. I am a happy camper! I will continue to keep track of the number of hours I run and check the bearings again after another 5 hours. For anyone interested... Here is a list of broke parts that I have replaced so far: Hot Racing Front Bulkhead (UPGRADE) Fast Eddy Bearing kit (OEM blew apart and UPGRADED) Hot Racing Aluminum Front Body Mount Base (BROKEN) AX31029: Axial XL Rear Sway Bar Parts Yeti (BROKEN) AX31006: Axial XL Chassis Cage Components (BROKEN) AX31004: Axial Rear Shock Mount (BROKEN) AX31225: Axial 2Universal Joint Dogbones - 123mm (Bent when I hit a tree) Dhawk Steering Bell Crank (UPGRADE) 1 Plastic shock cap (BROKEN) AXI31222: Axial Racing 2522 Universal Joint Rebuild Kit (2) (BROKE PIN) Overall I am pleased. I believe the initial differential issues I experienced were due to low quality bearings and flex in the OEM plastic front bulkhead. |
Axial Yeti XL and Hot Racing Bulkhead - Similar Threads | ||||
Anyone use hot racing rims on their yeti? | komeleoneyes | Axial Yeti | 1 | 12-12-2015 12:37 AM |
opinions? HOT-RACING YET48G01 Aluminum Graphite Steering Bellcrank AXI Yeti | 8000ft | Axial Yeti | 24 | 09-21-2015 12:58 PM |
Hot Racing Piggyback shock upgrade for Yeti XL | BobTeagle | Axial Yeti XL | 9 | 03-23-2015 12:41 PM |
