Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Has anyone installed the GPM aluminum rear damper mount?
Old 04-22-2016, 02:04 PM   #1
Default Has anyone installed the GPM aluminum rear damper mount?
Hi everyone, I have a Yeti XL kit that I'm upgrading right now. I bought the GPM aluminum rear damper mounts which can be seen here: GPM Racing Axial Yeti XL Aluminium Rear Damper Mount - 2Pcs Set Gun Metal YTL030
So I'm assuming these pieces just kind of sit on top of the existing plastic rear damper mounts? Are you guys using the stock screws and just not caring that they no longer screw in as far due to the added thickness of the aluminum damper mount?
Also what are the 2 included screws and nuts used for? Does it have anything to do with the 2 mystery screws on the bottom? I can't imagine anyone would want to mount their shocks there.
Thanks in advance for any info you might have!
daveflave1275 is offline   Reply With Quote
Old 04-22-2016, 02:12 PM   #2
Default Re: Has anyone installed the GPM aluminum rear damper mount?
I just got mine last week. I used stock screws for the mount and the included screws and nuts for the shock.
TUKN18Z is offline   Reply With Quote
Old 04-22-2016, 02:13 PM   #3
Old 04-22-2016, 02:27 PM   #4
The shock stem goes inside of the support and the plate covers the support
BarHarborBasher is offline   Reply With Quote
Old 04-22-2016, 03:42 PM   #5
Oh, so I put it on the wrong side. I feel dumb now. Thanks for the clarification.
Old 04-22-2016, 04:07 PM   #6
Oho I've been there too LOL
Old 04-22-2016, 05:52 PM   #7
Sometimes instructions really do help, I just usually don't read them.....LOL
Old 04-22-2016, 10:53 PM   #8
I used stock screws to mount it and left shocks in stock location. The 2 extra bottom holes are other shock mount options. I used the bottom rear hole for my HR 140mm limit strap.
84yoda is offline   Reply With Quote
Has anyone installed the GPM aluminum rear damper mount? - Similar Threads
GPM steel rear driveshaft pro mod steve Axial Yeti XL 44 01-26-2016 10:52 PM
Rear shock damper by gpm gregm412 Axial Yeti XL 4 08-27-2015 08:49 AM
GPM rear diff gears vinnyphx Tamiya XC/CC01 1 07-01-2014 08:09 AM
Installed Aluminum kit... rear links seem to bind on shocks jebby Axial AX-10 Scorpion 13 02-01-2010 10:12 PM
