06-01-2017, 11:10 PM | #101 |
Pebble Pounder Join Date: Apr 2017 Location: Fresno
| Re: What Did You Do to Your Yeti XL Today?
blew out my front diff :( need to do a tear down to see what failed. Was running it hard at a farm in super soft dirt spinning the tires and drifting turns.... then pounding it through the tilled rows. btw this thing is really hard to drive as a RWD drifter :o _________________________ update. Good News; only broken dog bone. Bad news, the stupid hot racing 17mm hex hub adapters for the RTR front axles is stuck. one of them looks is jammed on, even after removing set screw. Others I could use a rubber mallet and tap and they would come off. This one I have been at it for an hour and it isnt coming off. So I need to buy the Kit front axles and new knuckles and carriers.... Shuld have never got those HR 17mm adapters. Waste of $$ :( Last edited by Adidas4275; 06-02-2017 at 02:39 AM. |
06-04-2017, 08:04 AM | #102 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
The HR adapters are the cats ass with the RTR with stock wheels..Yeah they can be a pain in the ass to remove but way better than stripping a wheel in 5 minutes.. I've fell victim by using too much loctie... I just set the hex over my vice and reinstalled the Allen screw 1/2 way and simple tapped it out....
06-05-2017, 12:05 AM | #103 |
i got it off, took 2 days on and off of working on it...... and replaced the dogbone and an integy steering rack and some GPM upper links. Need to get a new lexan body to do a new paint job on it. and need to redo my rear diff with 1m oil |
06-10-2017, 06:10 PM | #104 | |
Pebble Pounder Join Date: Feb 2017 Location: Droning
[QUOTE=pro mod steve;5712912] Quote:
So I'm trying to setup this new RR Gen 3 64T slipper clutch and I found if you tighten the nut all the way and back off a quarter turn like the instructions say, it will no roll the tires when pushed across the floor like the stock slipper clutch did. When I power it up and run it that way the spur gear gets really hot fast. If I loosen the nut enough where I can push and roll the tires across the floor, the clutch slips way too much when I power it up and run it. Did you guys run into this problem? This slipper clutch had a lot of great reviews and am still trying to figure it out. Worst case I will just put the stock one back in but if anybody has any input it would be appreciated. | |
06-11-2017, 02:39 PM | #105 |
So I found a thread on this specific clutch. Turns out you need to tighten the nut all the way and break it in. As you go along you may need to tighten it more. In doing this the spur gear ran a lot cooler this time. I could actually rest my fingers on it. Before it must of been over 200 degrees because it was actually slipping too much. It actually handles better now with acceleration and control on loose gravel.
06-11-2017, 04:16 PM | #106 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
I tried the RR slipper with not so good results. Twice when I finally got the friction ring bedded or seated in where it worked great it cracked. Good luck hope all works out for you.
06-11-2017, 06:39 PM | #107 | |
| Re: What Did You Do to Your Yeti XL Today? Quote:
I hear you Steve. If it gives out on me I'll probably just go back to stock. I might get new pads and tighten the nut more with the old slipper clutch. But for now this appears to be an improvement. I'll have to see if it maintains. | |
06-21-2017, 01:01 PM | #108 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
Did some good old fashioned, hard core rock racing. After taking a couple of pictures I tried to do a video of it hauling ass down a gravel road, Tx in one hand, iPhone in the other. Bad idea! While trying to hit the play button I accidentally sent the trigger in full reverse. The beast did a perfect forward somersault about 10-15 feet then a couple of cartwheels and landed squarely on all fours. Unfortunately didn't catch it on video (video only has blurry gravel at my running feet and me yelling "Oh s*%t! You can see the wiped clean area on th spare which took most of the impact. Good news is no harm done except to my pride. Unscathed and ready to go again. http://www.rccrawler.com/forum/attac...1&d=1498071582 http://www.rccrawler.com/forum/attac...1&d=1498071582 |
06-26-2017, 06:40 PM | #109 |
my RTR has the plastic steering links and I like them since my 3 yo son hits stuff pretty hard..... but they have a lot of slop. So I replaced the plastic balls with metal ones and I have noticed much better handling. a good compromise between adjustable metal links and plastic ones
07-01-2017, 04:28 PM | #110 |
Newbie Join Date: Nov 2016 Location: Moscow
May be for some body it will be useful. I tried new lipo batteries 4S. It's not for bashers (not 6S) =) For me is important not voltage, but capacity of batteries for crawling and mudding. I found maximum size of 4s batteries for Yeti XL. The model is Team Orion LiPo 5300 4S 14,8V 50C But you will need to cut some plastic from battery tray doors =) So if you connect parallel you will get 10600 mAh!!! Here is some photo: |
07-02-2017, 04:57 PM | #111 |
Also GREAT for 8s runs ! Good find
07-26-2017, 08:46 AM | #112 |
Hi! Use this video and make hi clearence! https://www.youtube.com/watch?v=XBTh...__XxQ&index=27 But I use rods from traxxas jato. It's really hi! =) Also install radio box from traxxas summit/revo because its more waterproof, and put it higher then stock radiobox. For me it's important, because my yeti is always in mud and water =)) And one more =) Installed very cool rims from TFL compare to stock I like this car =) |
07-26-2017, 11:37 AM | #113 |
Looks great ! Works even better ! He didn't get to mention 126 mm CVDs, Dremel modding of the chassis plate and slightly sanding the upper-inner knuckle carrier for CVD clearance helps.
07-30-2017, 12:50 AM | #114 |
looking to see why I lost power to the front tires from about a week ago.... and... All 4 screws holding the gear to the diff cup had ripped out of the plastic diff cup :/ Replacing it with a GPM or Hot Racing metal diff cup Anyone else have this happen? Also picked up the GPM font bulkhead |
08-01-2017, 03:27 PM | #115 | |
Newbie Join Date: Jul 2017 Location: NorCal
I have never heard of that happening, I think there may be bigger issues....something seized that thing up. | |
08-07-2017, 12:32 AM | #116 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: What Did You Do to Your Yeti XL Today? |
09-12-2017, 03:51 PM | #117 |
01-06-2018, 04:30 PM | #118 |
What Did You Do to Your Yeti XL Today? - Similar Threads | ||||
What did you do to/with your Yeti today? | DTB1 | Axial Yeti | 348 | 11-30-2019 12:23 AM |
Got my Yeti today, not impressed at all so far... | rm25x | Axial Yeti | 309 | 02-10-2016 10:30 PM |
just picked up a used Yeti XL today | Megadesertdiesel | Axial Yeti XL | 14 | 05-21-2015 12:07 AM |
Yeti captured today | im gunna crawl | Axial Yeti | 4 | 08-28-2014 08:58 PM |
I drove a Yeti today. | Dirt51 | Axial Yeti | 1 | 07-12-2014 08:15 PM |
