06-07-2017, 05:20 PM | #41 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
| Re: Finished!
I'm over it Totally frustrated with trying to solder Castle BEC to my Vanguard ESC. Is there an ESC out there I can use to run my Hitec 7950 without having to use an external BEC? |
06-07-2017, 05:30 PM | #42 |
| Re: Finished!
Mamba X or the MMX. Tekin also has a beauty. What batt connector are you using ? Deans, no solder solution . Hang up and Drive |
06-07-2017, 06:12 PM | #43 |
| Re: Finished!
Yes, I'm using Deans. Can't quite make out what you've got there |
06-07-2017, 06:40 PM | #44 |
| Re: Finished!
Two deans plugs male/female back to back, bec leads solder in between, heat shrink over. Now plug bec between esc and battery Hang up and Drive |
06-07-2017, 07:00 PM | #45 |
| Re: Finished!
Gotcha... It was trying to solder 10 gauge wires plus bec leads together that's a pita. What shrink wrap did you use? |
06-07-2017, 07:02 PM | #46 |
| Re: Finished!
Found it in my bin, commercial from elec supply Hang up and Drive |
06-07-2017, 08:37 PM | #47 |
| Re: Finished! Thanks I'll give it a try. |
06-07-2017, 08:50 PM | #48 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
| Re: Finished!
If it helps you, I have an extra one of these I can mail you. PM you address and I will put it in the mail tomorrow. Just solder onto the little wires and your done. |
06-07-2017, 09:03 PM | #49 |
| Re: Finished!
Very generous, thanks!
06-14-2017, 04:26 PM | #50 |
| Re: Finished!
Did a novice job but it works and I think it will hold up. Thank you MaxxPain! http://www.rccrawler.com/forum/attac...1&d=1497479160 |
06-14-2017, 06:15 PM | #51 |
| Re: Finished!
Finally got the #%*#! Thing in. I'll use 2 sided tape to secure BEC into extra receiver box, leads are kind of short, I have to twist ESC wires around to connect to batteries. Should be okay. Is there a lid to that extra receiver box available? http://www.rccrawler.com/forum/attac...1&d=1497485717 |
Finished! - Similar Threads | ||||
Ever Done This? (finished!) | monkeyracing | Tamiya XC/CC01 | 4 | 05-07-2014 10:17 PM |
just finished w.k | fast625 | HPI Wheely King | 0 | 08-17-2008 10:06 PM |
Finished | CLODMAN360 | Tamiya Clod Buster | 1 | 05-29-2006 11:59 AM |
almost finished | yamaharider308a | General Crawlers | 2 | 04-16-2006 09:18 PM |
TLT finished! Half aluminum tube High gc Low cg FINISHED | RCMFMaxxMan | Tamiya TLT Crawlers | 12 | 08-08-2005 12:18 AM |
