Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Yeti XL 8S upgrade
Old 06-09-2017, 02:27 PM   #1
Default Yeti XL 8S upgrade
In the spirit of pushing it to the limit, I decided to go for 8S on this rig. I'm having a blast on 6S and it seems she could handle more, so why not.
This is the motor I decided to go with. The Poseidon 1527-C15, 1500KV. It has the same diameter of the stock motor just longer which means more torque and cooler temps, hopefully, and it's rated for 8S.
Since it has the same diameter I could use the same motor mount but I had to sacrifice my rear sway bar at the moment. Still going to try to use it but have to relocate the crossbar. For ESC I went with the Castle Mamba XL X. I mounted it on a plate and mounted that on the tower cross brace.
This is the motor mounted in the motor plate. I upgraded to the HR aluminum motor plate and heat sink. Also I went with the RR 64T spur gear slipper clutch.
Still in the process of dialing it in. To start of with I'm using a RR 19T pinion. The motor has a lower rpm so I have to gear up. I have to find the balance between speed and moderate motor/ESC temps. Also there might be a slight break in period for that RR slipper clutch. Im gonna work on getting a top speed of maybe about 45-50mph before moving it on up to 8S. But right now she lives.
mtr1514 is offline   Reply With Quote
Old 06-09-2017, 03:21 PM   #2
Default Re: Yeti XL 8S upgrade
GREAT WORK!!!!!! That car is a beast!!!!! Impressive work bro keep up the good work
Jeo-15 is offline   Reply With Quote
Old 06-09-2017, 03:26 PM   #3
Good stuff Bud
BarHarborBasher is offline   Reply With Quote
Old 06-09-2017, 10:13 PM   #4
What set of of upper and lower turn buckles did you go with?
Old 06-09-2017, 11:34 PM   #5
Ive always used GPM aluminum tie rods.
Old 06-10-2017, 12:22 AM   #6
Are those links all the same size?
Old 06-10-2017, 12:41 AM   #7
They come already sized to the factory specs but they are adjustable. They have plenty of room to adjust your toe and camber.
Old 06-10-2017, 12:45 AM   #8
Would you prefer these or the steel pairs that come with the kit?
Old 06-10-2017, 01:02 AM   #9
Though my Yeti Xl is an RTR, I am familiar with the Yeti 1/10 scale kit turnbuckles. I found with those that there was little room to adjust them out. These have more of a band to adjust. Overall they both work but I prefer the GPM for this reason.
Old 06-10-2017, 01:04 AM   #10
I'll be going gpm then! Thanks a million for the help I truly appreciate it
Old 06-14-2017, 01:53 PM   #11
So they have arrived. I decided to go with SMC 4S batteries 6700mah.
Ive been breaking in the new setup and everything is running great. I have a new Robinson Racing slipper clutch with 64T spur gear that I was babying but it broke in nicely. With a 19T pinion gear, everything is running cool but I'm picking up a temperature gun today to record actual temperatures. Also the new gearing already has the rig going a lot faster than before so I hope to get a speed test done as well and I will post results.
Old 06-21-2017, 02:49 AM   #12
So far so good. I started with a 19T pinion gear and went up to a 20T pinion gear but I believe I'm still under geared. I only hit a top speed of 35mph so I ordered and am waiting on a 21T and 22T pinion gears. Could be I need a longer stretch a road though to reach full speed. Also I ran it in >90 degree outside temperature and the motor barely hit 130 degrees after twenty minutes of full throttle speed runs. I also have a Yeah Racing heat sink with two 30x30mm fans that I got a while ago just for the summer. So I'm gonna add that as a precaution/buffer.
In the mean time I added some Arrma large battery trays to house my new 4S batteries. Pretty easy mod and they are mounted on solid. Not the best way I know because it's raising the center of gravity but I didn't see an alternative. I think it'll give way to some crazy bashing.
Old 06-21-2017, 09:16 AM   #13
Amazing work!!!!
Yeti XL 8S upgrade - Similar Threads
Upgrade the Wraith or get a Yeti? photocycler Axial Wraith 33 03-01-2015 03:07 PM
