![]() | #1 |
Newbie Join Date: Oct 2017 Location: sioux city
I just recently bought a used yeti xl rtr with some upgrades. I have never used a axial rc yet but the range is only about 100 ft then it starts cutting out. It has the ax-3 transmitter, not sure on receiver figure its the rtr original. I have a traxxas slash 4x4 that will go feels like forever and will never cut out on me. Just wondering if anyone has had similar issues and what would be the fix?
![]() | #2 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
Checked your batteries?
![]() | #3 |
Had new batteries since I got it. Only had it a couple weeks.
![]() | #4 |
Try rebinding the controler and reciver i had the same issue with my rtr xl it was the reciver for some reason it dident work in the xl its fine in my crawler i dont ever need to be that far away from the crawler the transmitter has good range with other recivers i bought a tactic set up for the yeti other than haveing 3 channels its not alot better than the ax3 / flysky that they come with you can get recivers cheap ether axial or flysky
![]() | #5 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
Is the antenna cut or folded at all? That would knock your range down quite a lot.
![]() | #6 |
I'll have to check that out and try it. Been waiting for my new aluminum servo horn. Plastic one stripped out the splines.
![]() | #7 |
Got a Flysky GR3E receiver to replace the ax-3 receiver. Have to get it out and test it sometime. Also got a Savox SC-1256TG servo to replace the original one that failed.
![]() | #8 |
Quarry Creeper Join Date: Mar 2015 Location: florida
Just an add on if your RTR came with the original AE-4 ESC and 2200 kv motor you will need to add a BEC on your setup specially now that your upgrading to Savox servo a glitch buster will not suffice. And this is why the AE-4 is the same as the castle sidewinder 8th with a 90 amp max rating re branded for Axial, the motor is the same as the old castle 1515 2200 kv with 120 amp rating. The RTR ESC doesn't have enough juice to power the motor and savox servos are notoriously power hungry it won't matter what transmitter/receiver you use you won't have just range issues but brownouts as well. In my RTR experience, I had range issues myself and like everyone else I thought it was the remote, I even bought a hitec remote but still had the same range issue. That is until some guys on the track saw my ESC/motor combo and suggested I install a BEC and the problem went away. Now I use the old ax-3 transmitter on the RTR and its just running fine and also no issues after installing a better servo when the original servo finally failed. Hope this helps keep bashing, stay safe and remember have fun doing it. |
![]() | #9 |
Flysky receiver and savox steering servo workikng great
Axial Yeti - Driveline Issue | PunchFatty | Newbie General | 2 | 12-25-2016 11:07 PM |
Axial yeti tire mounting issue | -SCXD90- | Axial Yeti | 17 | 03-01-2016 08:13 PM |
Yeti XL Steering issue | RandyClose | Axial Yeti XL | 9 | 10-19-2015 10:58 PM |
Axial Yeti XL transmitter range problem | Slimpickins | Electronics | 2 | 01-11-2015 09:29 PM |
Spektrum SR300 Range Issue | Knarly Nerd | Electronics | 24 | 06-10-2010 01:25 AM |
