02-25-2018, 09:13 AM | #1 |
Newbie Join Date: Feb 2018 Location: Denmark
| Need tires and wheel advice
I have been reading a lot about tires and wheel and that it’s not recommended to to go to heavy for a combo of tires and wheels as it puts to much stress on the electronics and driveline Original tires and wheel is 374 grams So what do people recommend for tires and wheels beside the stock ones ? I have been thinking about https://pitbullrc.com/products/pb9009zdk As they are about 284grams And for wheels https://store.rc4wd.com/RC4WD-Dick-C...ls_p_4237.html as they are 274grams For a total of 578 grams for wheel and tires that’s 204grams more than stock |
02-25-2018, 05:41 PM | #2 |
Rock Stacker Join Date: Feb 2017 Location: Finland
| Re: Need tires and wheel advice
Pit bulls are super! Dick cepeks are a bit heavier than stock but not too bad. This combo is far from alloy beadlocks&mudslingers combo that is like 900g per tire/wheel/foam in one corner.... I’ve tried quite a many setups, and I still like the stock KIT wheel&tire combo with CI foams. The first set I had with stock foams has cracked all 5 wheels....with CI foams the wheels don’t hit the ground anymore when landing and haven’t really had any problems with them since even though my yxl is 20lbs. |
02-26-2018, 09:26 AM | #3 | |
| Re: Need tires and wheel advice Quote:
Great answer and a cheap one aswell But I would have to remove the tires from the wheels and have never done this. I can see there are several methods to do it Acetone Bake them in the oven Boil in water Heat gun But which one is the correct one if I wanna reuse tires and wheels ? | |
02-26-2018, 09:35 AM | #4 |
Also I can see the stock kit tires are falken wildpeak While I have the RTR BFGoodrich Krawler tires Any recommendations on the difference ? |
02-27-2018, 09:55 AM | #5 |
Well ordered 3 pairs of CI foams as I have 3 pairs of stock tires and wheels. And if boiling or acetone ruins the tires and rims I gues I’ll just have to buy something new |
10-14-2018, 03:24 AM | #6 |
Rock Stacker Join Date: Dec 2013 Location: Omaha
Anyone out there know of a belted 3.8 set of tires and wheels that are not low profile? I’m looking everywhere. Trying to stay lower weight from stock or at least equal to. The src terrain crushers look decent but I’d like more sidewall. It seems tough to find something. By the way I’m just not good at gluing. I got it done on my kit stock set, but it was a messy fiasco. I spent a good amount of time on prep so hopefully they hold up. Pretty much any finishing type work doesn’t agree with me. I’m a mechanical guy.
10-23-2018, 11:56 AM | #7 | |
RCC Addict Join Date: Nov 2014 Location: Nowhere
10-24-2018, 06:43 PM | #8 |
Thanks for the reply. Yea, I did the gorilla tape method. 2 wraps before assembling the tires. I’m just anticipating them coming unglued and was looking for a factory glued set already with reinforcement
11-16-2018, 01:53 AM | #9 |
Newbie Join Date: Oct 2017 Location: Shepton Mallet
Hpi Baja desert busters 24mm hex no ballooning . Great grip. Total price for set of 4 is 45£ Wysane z mojego Mi MIX 2 przy uyciu Tapatalka |
Need tires and wheel advice - Similar Threads | ||||
Need more wheel and tire advice... | T4rscott | Tires and Wheels | 9 | 06-20-2017 01:03 PM |
Foff wheel advice | dittohead | Formula Offroad | 8 | 12-16-2013 09:03 AM |
wheel / tire advice | cmlooner33 | Axial XR10 | 6 | 08-26-2013 10:21 AM |
advice on 2.2 ripsaw tires on 1" aluminum wheel | Steelfish | Tires and Wheels | 11 | 09-26-2012 02:04 PM |
Need advice on wheel and tire choice!!! | Chaotic Crawlers | Superclass Crawlers | 7 | 09-22-2011 10:40 AM |
