![]() | #1 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
Did anyone bought this? Everything I bought from them is pretty good https://www.gpmracing.com.hk/en/prod...-MONSTER-BUGGY ![]() |
![]() | #2 |
Newbie ![]() Join Date: Feb 2018 Location: Denmark
I really like the hot racing axle better for the bigger bearings around the pinion, and remember that if you get the gmp axle to also order the diff cover as that’s not included with the axle. Also you would have to use the plastic extensions for the GMP while the hotracing as a split tube from wheel to wheel |
Has anyone installed the GPM aluminum rear damper mount? | daveflave1275 | Axial Yeti XL | 7 | 04-22-2016 10:53 PM |
GPM steel rear driveshaft | pro mod steve | Axial Yeti XL | 44 | 01-26-2016 10:52 PM |
Rear shock damper by gpm | gregm412 | Axial Yeti XL | 4 | 08-27-2015 08:49 AM |
GPM rear diff gears | vinnyphx | Tamiya XC/CC01 | 1 | 07-01-2014 08:09 AM |
