Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Sensored or Sensorless? For trails, mild crawling and mixed surface
Old 05-19-2018, 11:57 PM   #1
Default Sensored or Sensorless? For trails, mild crawling and mixed surface
Ok trying to work out a ESC/motor setup for the XL.
looking for 4-6 capability. and no more than $200-250.
Trying to decide between sensored or sensorless. Reading up seems to get mixed answers on how recommended sensored is. Sensored seems like a really good idea but does come with a price increase.
I'm sure I'll use it on mixed surfaces and probably a small bit of crawling is on trials.
Since I'm kinda wanting the 6s ludicrous speed I may install a 2 speed trans as well.
One combo I'm looking at is the Hobbywing EZRun Max8 w/ 2200kv combo, but is sensorless.
Any guidance would be great!
As somebody else said here before "I can't wait to get this done so I can break stuff"
Mayday! is offline   Reply With Quote
Old 05-20-2018, 01:03 AM   #2
Default Re: Sensored or Sensorless? For trails, mild crawling and mixed surface
I would buy a non-sensored motor if I were on a budget. Otherwise get the sensored setup.
MaxxPain is offline   Reply With Quote
Old 05-20-2018, 04:22 AM   #3
You can get a reliable aensored setup for under $200.
If it's going to get wet don't get sensored because the sensor chip in the motors are not waterproof.
Sent from my SM-G935F using Tapatalk
Spunkybob is offline   Reply With Quote
Old 05-20-2018, 11:16 AM   #4
Any suggestions on said sub $200 setup?
Also after looking at how sensored motors come apart I think I could conformal coat it.
Originally Posted by Spunkybob View Post
You can get a reliable sensored setup for under $200.
Old 05-20-2018, 02:47 PM   #5
If on a budget go with the stock esc and motor off eBay... it's made by Castle Creations. With your budget you're not going to be able to afford a sensored setup. I think you'll find this stock motor cogs a bit at low speed but you could easily fix it with gearing or a 2 speed transmission kit
daign is offline   Reply With Quote
Old 05-20-2018, 04:52 PM   #6
The castle 2200 sensored is waterproof and is completely amazing here’s a running video of my chained up straight axle with stock pinion/spur https://instagram.com/p/Bd768XxBWe2/
BarHarborBasher is offline   Reply With Quote
Old 05-20-2018, 05:12 PM   #7
You can get a HobbyKing 1/8 2-6s sensored esc for about $100 then spend the rest on any sensored motor.
I have had great success with the motors from goolrc, HobbyWing and HobbyKing.
I have used the 1:10 version for onroad racing for over 2 years and it was bulletproof.
ESC:
https://hobbyking.com/en_us/tracksta...grammable.html
Motor:
https://hobbyking.com/en_us/turnigy-...or-2100kv.html
Yes there are brand snobs and I'm not saying it's the best setup money can buy but it will be reliable.
Or spend an extra $40 on a HobbyWing xerun ESC with that motor.
Most sensored motors are only 4s
Old 05-20-2018, 08:45 PM   #8
So there is the CC 1/8 water proof combo that's sensored. it's $259 which I could go for.
I believe the 1515 2200kv motor.
Would this be anymore power over stock?
Otherwise I could just find a stock motor and get a decent ESC.
Sensored or Sensorless? For trails, mild crawling and mixed surface - Similar Threads
Sensored vs sensorless 4 pole brush less for rock racing and crawling gfmucci Electronics 8 05-25-2015 08:10 AM
sensored acting like sensorless minicrawlerguy530 Electronics 11 04-04-2013 02:11 PM
sensorless vs sensored? theloudone Electronics 3 03-26-2012 01:16 PM
Anyone running sensorless motors or just sensored?? Ty-bo Tamiya Clod Buster 1 09-21-2009 07:19 PM
sensored & sensorless HRT5SLCFD Electronics 3 05-05-2009 04:04 AM
