05-08-2015, 10:45 PM | #1 |
Newbie Join Date: Mar 2015 Location: Vancouver
| Anyone running on 4s?
Thinking of dropping in a motor and esc to run 4s. Has anyone done this and any ideas on how to mod the battery tray?
05-08-2015, 11:21 PM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
| Re: Anyone running on 4s?
Ty from Tekin is.....just need to buy the right sized 4s and beef up everything! Lol Sent from my iPhone using Tapatalk |
05-09-2015, 06:28 AM | #3 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
I'm building a kit using the Tekin RX8/Pro4HD 3000kv combo and I'm gonna run 4s. Max amps has a 4s 5450 pack that will fit perfect.
05-09-2015, 06:51 AM | #4 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
In the manual the batt tray dimensions are there. 145x52x35 or something close. Hobbyking has a battery finder menu. Select the appropriate dimensions and buy the battery. I've looked for 4s and there are a bunch. Will fit perfect and be less than $50 40c rating or above. |
05-09-2015, 09:14 AM | #5 |
Quarry Creeper Join Date: Dec 2014 Location: Plainfield
Something like this? RX8/T8 and a big ole 4S pack. It required a bit of modification on the stock box. |
05-10-2015, 07:21 PM | #6 | |
| Re: Anyone running on 4s? Quote:
05-10-2015, 08:22 PM | #7 |
| Re: Anyone running on 4s? ZIPPY Flightmax 5000mAh 4S1P 45C (AR Warehouse) Turnigy 5000mAh 4S 35C Lipo Pack (AR Warehouse) ZIPPY Flightmax 4500mAh 4S1P 45C (AR Warehouse) You may not need the MAH you think you need. Increased voltage = increased runtimes. Put simply. EDIT: Slightly less amperage. 125 amp http://www.hobbyking.com/hobbyking/s...dProduct=14843 http://www.hobbyking.com/hobbyking/s...dProduct=16789 Last edited by robertjpjr; 05-10-2015 at 08:25 PM. |
05-11-2015, 10:22 AM | #8 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
I love the Yeti bodies! So I went wit a LST chassis and built a carbon top and installed a summit transmission. Now to work on it is a snap. 4 bolts and ether diff comes out pull 4 more and the trans and motor come out. I love the over sized shocks and the bomb proof diffs! WHAT I DON'T LIKE IS THE SHORT 14.2 WHEELBASE! My next mod is to use the wheel CVD's as dive shafts and make it a 18'' wheel base and use the Yeti XL body and the 1/5 beadlock wheels. Last edited by twissted; 05-11-2015 at 10:33 AM. |
07-08-2019, 11:44 AM | #9 |
Newbie Join Date: Jun 2019 Location: Seattle
4s is overkill
07-08-2019, 12:30 PM | #10 |
So a few things: #1 - This thread is 4 years old. #2 - You're new but twissted killed so many threads with his need to post how whatever random creation he built was better than a completely unrelated vehicle. That was a trip down memory lane. #3 - Your take is wrong, so I corrected it. |
07-08-2019, 02:57 PM | #11 |
RCC Addict Join Date: Jun 2016 Location: Germany
Can't handle my little Monster on 3s why should i go to 4s Gesendet von meinem Pixel 2 XL mit Tapatalk |
07-09-2019, 04:03 AM | #12 |
Rock Stacker Join Date: Mar 2015 Location: NL
Designed for 2s, will be ok on 3s, but be prepared to (st)rip a decent amount of parts on 4s. Or the Yeti itself.
08-21-2019, 01:02 PM | #13 |
Rock Stacker Join Date: Feb 2016 Location: Gorham, Maine
I'm running a 4s with a Castle 1512/Sidewinder 8th oj my truck. Smc 4500 mah 4s. Fits just right once you remove the factory hold down and convert to velcro
Anyone running on 4s? - Similar Threads | ||||
Ya'll running 35T motors, what pinion are you running? | concretejungle | Axial XR10 | 9 | 03-11-2012 08:18 PM |
running 1.9s | S ARR T 8 | Venom Creeper | 4 | 01-13-2010 03:03 PM |
Those running 3s Lipo - what are you running, what do you like? | goldmember | Team Losi Comp Crawler | 41 | 09-19-2009 06:39 AM |
