08-30-2014, 07:51 PM | #1 |
Rock Stacker Join Date: Aug 2009 Location: celebration
| Yeti steering
Im not sure if I installed something wrong when i switched my servo or not but the yeti seems to have very little steering. Im just curious if anyone else has experienced this.
08-30-2014, 08:33 PM | #2 |
Quarry Creeper Join Date: Mar 2014 Location: San Antonio
| Re: Yeti steering
Have you tried adjusting your dual rate setting on your controller? Mine was like that too out of the box, a little adjustment and voila full steering.
08-30-2014, 08:35 PM | #3 |
Newbie Join Date: Mar 2014 Location: Fairfax
| Re: Yeti steering
Yes I think this is going to be a common complaint very quickly. The decision to make the posts that the bellcranks sit on plastic with plastic bushings was a big mistake. I think the servo probably has enough power to move the wheels precisely, but the system itself lets it down. The dual sheer rack is an improvement from the old flat EXO rack since it doesn't allow the rack itself to rotate up into the drive shaft at full lock. Its just the system has too much give when you combine the soft servo saver spring and those plastic rods.
08-30-2014, 08:40 PM | #4 |
| Re: Yeti steering
I haven't taken mine on anything technical yet just some loose Texas powder drifting and thrashing with a few rock piles in my subdivision where there building new houses. It seemed great for that. I did however install Vanquish's dual sheer steering pins with bearings, not sure if that really helped as I didn't run it stock. Tomorrow I hope to find some washed out creek beds to bash in.
08-31-2014, 12:50 AM | #5 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Re: Yeti steering
Can't you just pop out the plastic bushings and replace them with ball bearings? It won't fix the flex in the bellcranks, but it should at least reduce binding. Anyway, the steering links on the Wraith and other similar vehicles have tons of flex too, so it's not like this is a new and unexpected problem. |
08-31-2014, 07:26 AM | #6 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
| Re: Yeti steering
Carter Fab was able to just install some 5x8 bearings in his bellcranks without any issues. I plan to do the same today.
08-31-2014, 06:06 PM | #7 |
Well for links I know the Slash rods fit the EXO and Yeti front end and you can usually pick up a set for around $10 on eBay. It also looks like the original EXO steel steering posts may fit, but I'm uncertain since the manual doesn't say. Honestly though I'd buy the VP posts because the Axial set runs $13 without bearings, the VA set runs $17 with bearings and we know it fits. |
08-31-2014, 07:37 PM | #8 |
Come and take them!® Join Date: Oct 2011 Location: Rolling Hill's of Maryland™
| Re: Yeti steering
Remove your servo saver spring and stretch it about 1/4". Tightens up everything. With the addition of VP steering rack, my chit is 75% better. Spring is strong, but try 2 large flathead screwdrivers and spread the coils, gently, trying not to offset spring. Little at a time, and read Harley's thread on this subject. |
Yeti steering - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
Yeti | michael | Texas | 8 | 11-09-2014 04:36 AM |
water yeti.. calling all yeti owners | going2fast | Axial Yeti | 11 | 11-02-2014 05:43 PM |
Yeti | Jimbow | Axial Yeti | 6 | 08-29-2014 12:54 PM |
Yeti in GA | Crawlininga | Axial Yeti | 0 | 08-28-2014 04:10 PM |
